-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Using regular drill for tapcon concrete screws? (http://www.diychatroom.com/f105/using-regular-drill-tapcon-concrete-screws-159568/)
crayola110 10-09-2012 07:01 PM
My drill seemed to work in putting the holes in the concrete. bolting toilet flange to concrete
Then I reread the directions saying only to use hammer drill
I only have a regular drill and an impact driver. Could I use one of these for putting the tapcon screw in? I don't want to spend money on hammer drill. This is
joecaption 10-09-2012 07:19 PM
I've never seen a masonry bit with a 1/4 hex shank that would work in a impact driver.
It's not going to do any harm to use a reguler drill just going to take 4 times at least to drill the hole. You should also keep stoping to suck out the dust,
Canarywood1 10-09-2012 08:09 PM
I think they mean to use a hammer drill to bore the holes for the tapcon,not to drive the screw itself,but i don't think i'd use an impact driver for the screw,might strip it out.
joecaption 10-09-2012 08:13 PM
I always drive my Tap-Con screws with my impact drive.
oh'mike 10-09-2012 08:48 PM
Hammer drills are used to drill the holes---using a standard drill will work---but the bits over heat and will not give you many holes.
You are fine---If you ever need to drill a lot of holes in masonry---then buy the hammer drill---
crayola110 10-10-2012 03:41 PM
Oh I see. So the Hammer is for the Holes.
It did take me a long time to drill with my regular drill. Luckily the screws did not overheat as I kept dipping the drill bit in water.
I'll just use my regular drill to install the Tapcon screws now
sorry, i am so confused about the different drills and what they're used for....
Thanks so much as always! :thumbsup:
