Using Masonry, Natural Stone, Or Faux Stone On Basement Walls? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-09-2013, 09:51 AM   #1
Using masonry, natural stone, or faux stone on basement walls?
I'm considering making an unfinished basement habitable.
When we moved in 3 years ago, water came into the cinder-block basement with every rain. So we fixed that. Dug tile runs for each downspout with popups away from the house, regraded the soil outside, and now it seems fine.
We have a dehumidifier in the basement that does draw water out every day. It probably runs 12 hours a day. I personally hate the thought of drywall and wood holding in the moisture that clearly wicks through the cinder block walls.. It sounds like a recipe for mold and decay.
I'm thinking about affixing masonry products (ex: thin brick veneer), natural stone (something permeable... Say travertine) or cultured faux stone to the exterior walls so that if a driving rain DOES cause a temporary appearance of water down the road, it isn't catastrophic.
Any suggestions? Good idea, bad idea? If I use a permeable material with mortar, will it allow continued normal evaporation process? Will the mortar hold? Will particulates stain the materials through the evaporative process?
Minich is offline   Reply With Quote
Old 04-09-2013, 10:40 AM   #2
Concrete & Masonry
Rewards Points: 470
Good thoughts, and kudos for understanding that the only place for vapor to migrate is IN......
I think it's a good idea, but it's going to be more expensive and time consuming than drywall, and have little to no insulation value, which is enough to turn most people away....
Yes.......
If installed correctly, and the water transmission isn't severe, then yes....
There is a chance that the masonry could accumulate some efflorresence if there's major water intrusion...
jomama45 is offline   Reply With Quote
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate? Minich Remodeling 8 02-01-2012 09:27 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Need opinions on insulation of basement walls mstemphoski Building & Construction 0 03-28-2011 11:15 AM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
