Using Both Block & Brick In Chimney - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-19-2012, 07:33 PM   #1
Hello Folks:
We have a mason extending our concrete block chimney a few feet higher to get it to the correct code height. He is using a mixture of both block and brick in these top few feet. The whole chimney will then be refaced in stone, so these blocks and bricks will not be seen.
Is it OK to use both together like this?
Allan
Allan In Sims is offline   Reply With Quote
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Building Chase Around a Brick Chimney TDFICH Roofing/Siding 2 05-17-2010 06:50 PM
Replacing a Brick Chimney GeauxCajuns82 Building & Construction 4 04-16-2009 07:20 PM
leak in chimney water comes threw brick Kdawg Roofing/Siding 51 02-08-2008 03:18 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 10:37 PM
