Using Belgian Block To Form Slate Covered Stoop - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-12-2012, 08:44 AM   #1
No pain, no gain!
Rewards Points: 89
Using Belgian block to form slate covered stoop
We are reconfiguring out house--new front door is in and sill is flashed.
I wanted to add a low stoop for the step up into the house.
I first planned to pour a simple concrete pad--but I acquired some Belgian block (granite sets) and slate and wondered about the feasibility of outlining the stoop with Belgian block set on end, filling the center area (combination of gravel and ?) and then laying slates on top.
The immediate area from the corner of the driveway to the stoop would be done in the same slate.
Would this work? If so, what would I need to do for a footing under the block (I'm assuming that I can't just lay them the way you would do driveway edging?)
Should I dry lay the slate on the rest of the area and use polymeric sand--or try to wet lay the whole area?--it is probably 10' x 20' but an irregular shape.
paredown is offline   Reply With Quote
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Need help Building form to extend front door stoop rocketdoctor Building & Construction 8 05-15-2009 03:44 PM
How to install belgian block? Tmb9862 Building & Construction 2 09-19-2008 05:50 PM
