Use White Sand - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-05-2013, 01:06 PM   #1
use white sand
Should white sand be mixed with white mortar to keep the mortar white?
rmyers is offline   Reply With Quote
Old 03-05-2013, 01:14 PM   #2
Rewards Points: 1,220
Usually not unless white sand is all you have. White sand is normally beach sand which means it is round and relatively smooth, masonry sand is normally a sharp sand. For glass block they often do use white sand though.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 03-06-2013, 11:52 AM   #3
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Years ago we made white concrete for a grocery store, and we had to have white sand, rocks, and cement. I imagine your situation would be similar, any colored sand would overpower the whiteness.
I hate signatures.
Mort is offline   Reply With Quote
Old 03-06-2013, 03:16 PM   #4
Rewards Points: 3,370
When we supplied the concrete for McDonalds Hamburger university training center,white concrete was specified for some floors,and they used 3 inches of regular concrete dry tamp for the base and topped it with white cement mixed with silica sand.
Canarywood1 is offline   Reply With Quote
Old 03-06-2013, 07:15 PM   #5
Mort's Avatar
Rewards Points: 690
I know why they do it, but wouldn't painting the floor white every couple years be cheaper than the $400 per yard we were charging?
I hate signatures.
Old 03-07-2013, 10:34 AM   #6
The sand color doesn't have any effect on a properly mixed and finished slab. If it will be ground, obviously this does not apply.
Old 03-09-2013, 07:58 AM   #7
Rewards Points: 4,454
white cement is all you need,,, IF you're really worried, call sher-wms for wtr soluble white pigment,,, we've done a couple floors for them guys - epoxy/urethane coatings after all the other trades were gone
Old 03-11-2013, 08:34 PM   #8
Rewards Points: 37
It you want it white you need to use white sand. Don't believe me get different colored sands & make test batches. They will be close to the color of sand you are using. The color of the sand has nothing to do with it is acceptable to use in a particular mix. The ASTM # does C-33 for concrete mixes & C-140 something for mortar mixes.
TOOL82 is offline   Reply With Quote
Old 03-11-2013, 08:39 PM   #9
If you have sand exposed on a concrete slab, then you either ground it or did not mix it properly. The paste will coat each particle of aggregate and thus the color of the sand does not matter for normally finished concrete.
For mortar ( ASTM C-144 is the proper standard, FYI) it depends upon how and when you tool it as to whether the sand will make a difference in the color. Normally, in mortar it does because the joints are tooled, exposing the sand.
Old 03-12-2013, 05:50 AM   #10
& that little lesson's priceless
Two black wires and two white wires in a ceiling mshaw11 Electrical 6 07-11-2012 10:57 PM
White distressed furnitures in a Mid Century? SBLima Interior Decorating 2 06-23-2012 10:11 PM
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 08:27 PM
black, white, white, black! bamaranch General DIY Discussions 5 07-04-2010 01:24 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
