Unused Fireplace Stack Behind Refrigerator - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-23-2012, 09:15 AM   #1
Rewards Points: 154
Unused fireplace stack behind refrigerator
Hi All,
I have a fireplace chimney stack right behind my fridge which makes the fridge stick out about 1.5 feet forward and not aligned with my counter top. The fireplace is in the way only on the right side about 1 feet. Would it be advised to chip away at the fireplace that 1 foot to the left and the height of the fridge until I can push the fridge all the way back?
If not advised, how else can I deal with this problem besides removing the entire fireplace. Is this something I have to just deal with?
Thanks.
llckll is offline   Reply With Quote
Old 08-23-2012, 12:18 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
Originally Posted by llckll View Post
Hi All,
Thanks.
That would not be a good idea, you could have brick or what ever the flue is made of crumble and hurt you. That flue surely goes through the roof and that is a lot of weight to have above your head especially when the support has been damaged by having a foot of it chipped away. Your best bet would be to get a qualified mason out there to give you advise.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-23-2012, 03:32 PM   #3
Rewards Points: 502
1.What is the chimney breast built of (brick,conc. block?)
2. how wide is it? (side to side).
3. one-storey or two stories high?
If the chimney is sufficiently wide, and built of brick, it is sometimes possible to cut a portion of it away. If the brickwork is in good condition, it will self-support due to the 'corbelling' effect, so long as there is sufficient width left.
tony.g is offline   Reply With Quote
Old 08-23-2012, 03:49 PM   #4
Rewards Points: 14,312
Your going to have to at least post a picture for even some guesses.
Someone would have to be on site to look the whole thing over, not people on the net that have never seen it and could be just about anyone.
OOPS! Stack disconnected when I tested my work... WillK Plumbing 1 02-20-2012 06:04 AM
Are cornerstones needed for faux dry stack stone fireplace? Lisa Highfield Building & Construction 0 06-09-2010 06:36 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
dry stack fireplace boddah General DIY Discussions 2 12-10-2007 02:53 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
