01-05-2013, 06:08 AM
#4
unfinished cement basement
this may be an abandoned thread however the last post begs a response,,, ' paint the interior with white elastomeric roofing ' stuff may be a solution depending on the resistance to hydrostatic pressure it has,,, IF the magic stuff's applied to a roof, that's the positive side of wtr - inside on a bsmt wall, that's the negative side,,,,,, but it won't stop collecting/leaking water UP thru a floor NOR will it prevent wtr from leaking thru the floor/bsmt wall til it reaches the ' magic stuff ',,, that's where it'll be free to wreak its damage on the structure unbeknownst to the owner cheap, ineffective way to resolve this imo but what do i know - did make a living at itfor 25 yrs
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
