Underground Natural Spring Under Concrete Slab Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-27-2014, 07:35 AM   #1
underground natural spring under concrete slab foundation
I wasnt sure which section to post this bit hopefully someone on here may have run into this before.
I have cut out a large section of concrete slab in a house and dug down to the main drain pipe to see if I could find a leak. It's nice and muddy down there and its definately accumulating water.
Here's what I've done so far:
Poured blue dye down drains throughout the house. No blue is showing in my hole after 2 days of dumping dye down drains.
I've marked the water meter to see if it could be leaking from supply pipe. The water meter has not moved
I think there is an underground spring under this concrete foundation house.
Does anyone know how I would go about diverting the water out from under this house?
yoshiaguas is offline   Reply With Quote
Old 03-27-2014, 07:51 AM   #2
Rewards Points: 2,838
Weeping tile system . very expensive.
trenched all around the outside of home, With several running under the home as well, then out of the property to a ditch somewhere, a lot of work involved.
Or a sump pump system .
ED
de-nagorg is online now   Reply With Quote
Old 03-27-2014, 07:59 AM   #3
Rewards Points: 626
were are you located at?
Nailbags is offline   Reply With Quote
Old 03-27-2014, 10:15 AM   #4
landfillwizard's Avatar
Rewards Points: 516
What type of soil did you find?
landfillwizard is offline   Reply With Quote
Concrete against older concrete foundation? AlphaPilot Concrete, Stone & Masonry 1 10-14-2012 09:45 AM
4" concrete slab, form, pour and finish ChiefVOL Building & Construction 10 01-20-2012 04:56 PM
Post-tension concrete foundation extension woody9911 Building & Construction 0 01-17-2011 05:26 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
