Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-30-2012, 06:38 PM   #1
macon, ga bibb county
Type of concrete for footings
I'm building a workshop/shed that will be 16x24 and have wood working tools and maybe a motorcycle and need to know what type of concrete I need to use for the footings I'm guessing type m for the footing and blocks for the piers
Lupus71 is offline   Reply With Quote
Old 09-30-2012, 07:27 PM   #2
Wondering what concrete to use for a 16x24 shed that will hold woodworking tools. Is regular sakrete
strong enough?
Old 09-30-2012, 07:31 PM   #3
I sure hope you do not plan on trying to do this with bags of concrete.
http://www.concretenetwork.com/concr...calculator.htm
Old 09-30-2012, 07:41 PM   #4
World's Tallest Midget
Mort's Avatar
3000psi, no air (if it isn't exposed to the elements) would be fine. If you're doing a slab/footing mono pour, just get a truck. You'll thank me later.
Mort is offline   Reply With Quote
Old 09-30-2012, 08:31 PM   #5
Sorry for not explaining better. It is not for a slab it will be 12 2x2 footings and probly 2 8" block high. Lowes has Portland type 1 but I'm not sure if that's what I need or if it's premixed.
Old 09-30-2012, 09:24 PM   #6
Wow if I did this right I need 48 60# bags to do 12 2x2x8 footings! That's $500 if I need to use Portland,which is $10 a bag! Man that just threw a wrench in things! Is there a cheaper way? I've seen sonotubes but they still need a footing right?
Old 09-30-2012, 09:59 PM   #7
google "shortload concrete" and make some calls.
in my case, the total price was slightly cheaper than bags, delivery, and mixer rental and I saved a ton of time by not mixing it myself.
good luck
allthumbsdiy is offline   Reply With Quote
Old 10-01-2012, 08:43 AM   #8
Well the problem with that Is I can't get a truck behind my house
Old 10-01-2012, 03:33 PM   #9
Mort's Avatar
It's still a thousand times easier to get a truck and a few wheelbarrows and wheeling it from the front than mixing all that Sakrete.
The Following 2 Users Say Thank You to Mort For This Useful Post:
GBrackins (10-01-2012), jomama45 (10-01-2012)
Old 10-01-2012, 04:28 PM   #10
GBrackins's Avatar
you know that's right Mort!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 04:27 PM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
