Type Of Bolt For Seismic Retrofit - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-09-2013, 01:48 PM   #1
Rewards Points: 526
Type of bolt for seismic retrofit
Hi there, I am looking to bolt my mud plate to my poured concrete foundation wall and I am not sure which kind of bolt would be best for my situation. As I understand, there are three main anchor methods for this type of work - undercut, wedge, and epoxy. The foundation is poured concrete, 90 years old, and is in good condition. The bolts I will be using are 5/8th diameter. What type of anchor method is recommended for old concrete? Thanks.
Windows is offline   Reply With Quote
Old 12-09-2013, 06:20 PM   #2
Rewards Points: 4,750
are your bolts simple threaded rod ? if so, epoxy works well,,, i like wedge/lead anchors best,,, why so big ? we use 1/2",,, careful drilling holes so you don't blow out the edge & spall the conc,,, its a pita to repair,,, don't ask me how i know this - i just know
The Following 2 Users Say Thank You to stadry For This Useful Post:
crayola110 (08-19-2015), Windows (12-10-2013)
Old 12-10-2013, 10:23 AM   #3
Rewards Points: 526
I read in several places that 5/8 or even 3/4 was the new recommended size for foundation bolting. Thanks for the tips.
Old 12-10-2013, 10:38 AM   #4
i'm a bit fuzzy on the spec but isn't 5/8 - 3/4 the size for vert rebar 4' o/c ? jomamma or joecap may chime in later
Old 12-12-2013, 05:23 PM   #5
Oso954's Avatar
Rewards Points: 1,338
It is for new construction, where you have more control over foundation size and bolt placement.
Smaller bolts are preferred for retrofit.
1/2 for up to 2 stories, 5/8 for 3 stories.
Here is a link to Seattle's Retrofit Handbook.
http://www.seattle.gov/emergency/lib...assessment.pdf
Oso954 is offline   Reply With Quote
Old 12-16-2013, 12:02 PM   #6
Rewards Points: 526
Thanks for linking to this. I have read it, but could be useful for others.
Old 08-19-2015, 12:55 PM   #7
Rewards Points: 213
Does anyone know if you can use mechanical anchors like Red Heads for bolting down foundation sill to the concrete wall?
crayola110 is offline   Reply With Quote
Door frame resize conflicts with anchor bolt colossus610 Building & Construction 8 09-22-2012 10:28 AM
en Flange bolt. Not sure how to proceed. latenight Plumbing 4 08-07-2012 05:01 PM
Toilet replacement: Spinning bolt Rufe Plumbing 7 07-07-2012 08:48 AM
What type of cat5e cable type fastener? Ranger31 Electrical 8 06-29-2011 09:01 AM
Help: Can you name the type of bolt this is? JohnZucco Carpentry 14 05-21-2011 04:35 PM
