-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Type of bolt for seismic retrofit (http://www.diychatroom.com/f105/type-bolt-seismic-retrofit-191788/)
Windows 12-09-2013 01:48 PM
Hi there, I am looking to bolt my mud plate to my poured concrete foundation wall and I am not sure which kind of bolt would be best for my situation. As I understand, there are three main anchor methods for this type of work - undercut, wedge, and epoxy. The foundation is poured concrete, 90 years old, and is in good condition. The bolts I will be using are 5/8th diameter. What type of anchor method is recommended for old concrete? Thanks.
stadry 12-09-2013 06:20 PM
are your bolts simple threaded rod ? if so, epoxy works well,,, i like wedge/lead anchors best,,, why so big ? we use 1/2",,, careful drilling holes so you don't blow out the edge & spall the conc,,, its a pita to repair,,, don't ask me how i know this - i just know :furious:
Windows 12-10-2013 10:23 AM
I read in several places that 5/8 or even 3/4 was the new recommended size for foundation bolting. Thanks for the tips.
stadry 12-10-2013 10:38 AM
i'm a bit fuzzy on the spec but isn't 5/8 - 3/4 the size for vert rebar 4' o/c ? jomamma or joecap may chime in later :yes:
Oso954 12-12-2013 05:23 PM
It is for new construction, where you have more control over foundation size and bolt placement.
Smaller bolts are preferred for retrofit.
1/2 for up to 2 stories, 5/8 for 3 stories.
Here is a link to Seattle's Retrofit Handbook.
http://www.seattle.gov/emergency/lib...assessment.pdf
Windows 12-16-2013 12:02 PM
Thanks for linking to this. I have read it, but could be useful for others.
crayola110 08-19-2015 12:55 PM
Does anyone know if you can use mechanical anchors like Red Heads for bolting down foundation sill to the concrete wall?
