Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-26-2012, 01:51 AM   #1
Tuckpointing pool coping-Question
I have a large pool coping project where i have to grind out about 125 joints on round nose brick and i was wondering is there a special additive (latex) r anything that should be added to the colored mortar i will be replacing the current with? Or will the type N be just fine? Wasnt sure because of the pool chemicals that could speed up the process of decay on the current mortar.
Thanks for reading.
TRUEPRO is offline   Reply With Quote
Old 09-26-2012, 04:57 PM   #2
Thanks for reading.
You should use a water proof epoxy grout,made for swimming pools,and a sealer made for swimming pools after grouting.
Canarywood1 is offline   Reply With Quote
Old 09-26-2012, 10:31 PM   #3
So using a colored TYPE N with Planicrete UA, a latex addictive for mortar repairs, and sealing that wont do the trick?
Heres the link to the product site.
http://www.mapei.com/us-en/products-search-results.asp
Old 09-27-2012, 08:21 AM   #4
Concrete & Masonry
Most of the brick I've fixed on pool coping hasn't failed from the chemicals of the water, but from "sloppy", loose filling of the joints. Most of them that I've worked on were set in the bedding material (usually mortar) and filled with a bag afterward, but were never pushed completely tight. If you consolidate the Type N mud with a filler/tuckpointing trowel, I think you'll be fine. Banding agent certainly won't hurt either. Also, don't forget to treat the control joints in the surrounding slab (only assuming the brick are bearing partially on the slab) as control joints where they intersect the brick..........
jomama45 is online now   Reply With Quote
Old 09-27-2012, 11:19 AM   #5
Is the pool a fresh water,or salt water??
Old 09-27-2012, 09:12 PM   #6
Fresh
Old 09-28-2012, 04:29 PM   #7
Fresh
Well,jomama says he's had no problems,but if the PH get's out of wack it could cause problems with the grout,personally i'd go with the epoxy but it's your call.
Filling in our InGround Swimming Pool wnewman Landscaping & Lawn Care 17 04-22-2013 08:27 AM
Pool Pump Bonding Question phxhomeowner Electrical 7 09-17-2012 02:46 PM
LED Pool Bulb Voltage Question Drywallhelp General Discussion 5 11-30-2011 10:06 PM
Bonding Pool Equipment - Conflicting Advice rickster18 Electrical 6 08-18-2011 06:21 PM
Inground Vinyl Pool Question intofire Landscaping & Lawn Care 0 09-11-2008 11:34 AM
