Tuckpointing - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-16-2012, 08:52 PM   #1
Tuckpointing
I notice there are 1/2" holes and loose vertical mortar joints between the cinder blocks on the very first course of the foundation wall in my above grade basement.
The course I am referring to is the very first one just below the 2"x4" studded wall.
I think the cracks comes from insects moving into the house. I can only see the gaps and loose mortar on the inside. The outside is surrounded by cement patio.
Can I use compress air to blowout what's loose fill in the gap with a mortar bag?
I don't want to make it worse but I am putting dry wall up soon.
kingofmycastle is offline   Reply With Quote
Old 10-16-2012, 09:03 PM   #2
Old 10-16-2012, 10:04 PM   #3
Rewards Points: 12,858
Chisle or grind it out. It's needs to be about 1/2 deep to hold the morter.
If it was mine I'd be using Hydrolic cement instead.
Is that a none pressure treated bottom plate?
tuckpointing garage rjc Building & Construction 1 02-11-2011 06:33 AM
Tuckpointing....Quikpoint Mortar Gun? clarson Building & Construction 4 08-13-2008 09:06 PM
Tuckpointing vs. Caulking NewUser1 Building & Construction 2 07-09-2008 09:33 AM
Tuckpointing to fix basement dampness (with pics)? WhammyRose Remodeling 6 01-31-2008 02:55 PM
Tuckpointing Question foxblaze Building & Construction 1 08-30-2006 08:43 PM
