Trimming Bottom Of Cultured Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-02-2012, 09:25 PM   #1
Trimming bottom of cultured stone
I'm getting ready to install some laminate wood in a room that will also go around a bar type structure that is covered with cultured stone. My issue is that the laminate is about an 1/8" to thick to go under the bottom of the cultured stone. I'm looking for some advice on possibly trimming the bottom of the stone so that the laminate will fit under it. If this is possible, is their a certain tool that you would suggest? I've attached a photo. Any advice would be greatly appreciated.
Thank you.
J.P.R. is offline   Reply With Quote
Old 11-02-2012, 09:39 PM   #2
Rewards Points: 13,274
Got an ossilating saw?
I would try flipping a piece of flooring over to use as a guide and try my ossilating saw with the diamond blade. If that failed I'd be using my 4-1/2" right angle with a diamond blade.
J.P.R. (11-08-2012)
Cultured Stone fireplace lindyloo Concrete, Stone & Masonry 3 10-31-2012 05:32 PM
cultured stone mortar type? tpagel Building & Construction 7 07-01-2009 06:57 PM
Looking for a cultured or natural stone product Tarpon General DIY Discussions 1 06-24-2008 08:11 PM
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 06:38 AM
cultured stone mortar mix? ducter Building & Construction 1 09-18-2006 08:44 PM
