-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Trenching slab, what to use (http://www.diychatroom.com/f105/trenching-slab-what-use-158307/)
Joe442 09-28-2012 06:03 PM
I putting a new floor down in kitchen and I want to bury radiator line under the slab. Would a small breaker hammer do this or create cracks in the slab? Thought about a concrete saw but the dust will be bad. Only need to go 6 feet.
stubborn1 09-29-2012 08:29 AM
I would use a rotohammer with a point bit and chip away at it, or since you are only going 6' you could use the old faithful sledge hammer. As long as the slab isn't massively thick it shouldn't take you a long time either way.
Mort 09-29-2012 10:29 AM
The only way I'd think to do it without cracking the slab would be the saw. Just tarp everything and the dust will be contained.
Joe442 09-29-2012 05:25 PM
1 Attachment(s)
I got the small demo hammer this morning. I did have to hang plastic as this was very dusty as well. Looks like a little Dexter room. You have to know the show to know what I'm talking about.
Did the job no cracks. Started with the wide chisel to outline and then the pointy one down the middle. Taking up the rest of my ceramic tile before I bring it back so was worth getting this. If I was to do it again and only need to trench I would go with the saw since the dust was bad either way.
Attachment 58116
jomama45 09-30-2012 12:34 PM
We do lots of this, although it's almost always in the basement floor here. An electric 14" cut-off saw with a water mist, as well as someone sucking up the slurry before it runs too far away, is the least obtrusive way I've found yet. Very little dust, fast, no fumes, and the easiest to patch back into.......
