Travertine Around A Fireplace - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-02-2012, 09:28 AM   #1
travertine around a fireplace
What is the best way to attach travertine stone to brick around the opening of a fireplace?
hinkd007 is offline   Reply With Quote
Old 07-02-2012, 10:31 AM   #2
www.No-Curb.com
JohnFRWhipple's Avatar
What is around your fireplace opening right now?
I would suggest you rig up a few tiles and run your fireplace. Many Travertine tiles are filled with a resin or epoxy that can change colour from the heat. I would test the effects of the heat on your tile.
Regular thin-set or dryset setting materials offer up very little flexibility so I would suggest you set the tile with a S2 thinset like Mapei's Grani-Rapid.
Good Luck.
JW
"When it's Perfect. It's good Enough." - John Whipple
JohnFRWhipple is offline   Reply With Quote
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
