Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-25-2012, 08:45 PM   #1
Tiling over concrete joints on patio
Hi,
I am a homeowner considering having porcelain tile installed over a 600sqft concrete slab on my patio (around 30 yrs old or so).
My main concern is that the slab is divided into 4 sections by bricks, which create big joint lines (please see the pics for more detail). Although there are no apparent cracks (except for a thin one), I am afraid to tile on top of it all to find out a year or so later that there is floor movement and ruin my tiles.
I have been told that it was not a problem at all, that it is a big concern, I have heard about "Schluter®-DITRA", I have been told about "adding a membrane on top of the joints", so at this point I am confused as to which way to go (or not go).
I am considering having the concrete stamped instead (I had it done in my driveway 3 years ago and it still looks good) but I would rather go with the tiles if safe.
Thank you for any gidance you can share.
Best,
Ron
Tiling over concrete joints on patio-patio-concrete-slab-divided-bricks-1.jpg
roncarvalho is offline   Reply With Quote
Old 08-26-2012, 09:46 PM   #2
Originally Posted by roncarvalho View Post
Hi,
Best,
Ron
I'd say it's a gamble going either way but hey,it's your call.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
roncarvalho (08-26-2012)
Old 08-26-2012, 11:03 PM   #3
I'm not really a gambler type of guy, so I will likely go the stamped concrete route with stencil...
Old 08-27-2012, 10:03 PM   #4
Concrete & Masonry
Do you really think that patio's that old? I'd guess less than 10 years from the small picture, but I'm sure there's a good reason you want to cover it. Personally, I think you need a decoupling membrane at a very minimum, as I see no way those joints aren't going to telegraph throw in a short amount of time.............
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
roncarvalho (08-28-2012)
Concrete Patio Enclose with Pressure Treated Wood ryanb4614 Concrete, Stone & Masonry 8 04-23-2012 07:22 AM
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 10:03 AM
Concrete patio control joint marriedmanw Building & Construction 1 07-29-2011 07:23 PM
Filling/covering control joints while laying tile on concrete Marita Tiling, ceramics, marble 0 09-19-2010 02:46 PM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 06:27 AM
