Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-28-2012, 01:42 PM   #1
Tiling around fireplace with wall out of plumb
So my wife and I are tiling around our fireplace and the wall on the left side that abuts at a "right angle" with another wall (brick wall that has been mudded and textured) is not plumb by about 3/8" at the top and less as it goes down the wall to the floor. Any suggestions on how to fix this problem so we dont have to cut the tile that will fit but will not be square. Ideally we would like the surround to abut the edge of the wall and be in line with the hearth tile which has already been set. I attach a pic which may help to understand the issue
Tiling around fireplace with wall out of plumb-fireplace-pic-1.jpg   Tiling around fireplace with wall out of plumb-fireplace-2.jpg
DanielSF is offline   Reply With Quote
Old 11-28-2012, 07:03 PM   #2
Square it up from the bottom.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
oh'mike (11-28-2012)
Old 11-28-2012, 09:09 PM   #3
I guess you mean the wall is 3/8" loose on the left? 3/8" over 8'?
You didn't mention the type, size, bond pattern of tile.
I would want to just start with small joints at the bottom and open up as I go up the wall.
Consider a 1/2 or 1/3 bond.
cleveman is offline   Reply With Quote
Old 11-28-2012, 09:29 PM   #4
Cleveman, he has the plumbline drawn on the corner, it is too much to make it up in joints, although not using a stack bond would work, but look funny for tile.
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Tiling an outside wall over lathe and plaster and window mkjeld Building & Construction 8 10-28-2010 07:48 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 06:38 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
exterior wall out of plumb charliebrown314 Building & Construction 1 07-06-2009 03:09 PM
