-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Tiling around fireplace with wall out of plumb (http://www.diychatroom.com/f105/tiling-around-fireplace-wall-out-plumb-165000/)
DanielSF 11-28-2012 12:42 PM
2 Attachment(s)
So my wife and I are tiling around our fireplace and the wall on the left side that abuts at a "right angle" with another wall (brick wall that has been mudded and textured) is not plumb by about 3/8" at the top and less as it goes down the wall to the floor. Any suggestions on how to fix this problem so we dont have to cut the tile that will fit but will not be square. Ideally we would like the surround to abut the edge of the wall and be in line with the hearth tile which has already been set. I attach a pic which may help to understand the issue
Tscarborough 11-28-2012 06:03 PM
Square it up from the bottom.
cleveman 11-28-2012 08:09 PM
I guess you mean the wall is 3/8" loose on the left? 3/8" over 8'?
You didn't mention the type, size, bond pattern of tile.
I would want to just start with small joints at the bottom and open up as I go up the wall.
Consider a 1/2 or 1/3 bond.
Tscarborough 11-28-2012 08:29 PM
Cleveman, he has the plumbline drawn on the corner, it is too much to make it up in joints, although not using a stack bond would work, but look funny for tile.
