Tiles On Outdoor Bar - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-04-2013, 04:06 PM   #1
tiles on outdoor bar
the tiles on my outdoor bar/bbq fall off every spring!! how can I keep them on?
truckee5 is offline   Reply With Quote
Old 05-05-2013, 05:52 AM   #2
Rewards Points: 4,442
in general, many project failures are primarily fail due to sloppy labor OR incorrect material/method selection,,, w/o knowing where you're located, its impossible to either respond accurately OR venture a ' WAG ' too bad you didn't add that information as many of us are fairly decent when it comes to WAG's
Old 05-05-2013, 06:05 AM   #3
DIY staff
Rewards Points: 7,174
Tell us how it was done---someone will know why it failed--
Pictures help--location also----
Old 05-05-2013, 02:38 PM   #4
outdoor bbq bar tiles
sorry - the bbq/bar tiles that fall off every spring are located in truckee ca. I'm at 6000 ft and the winters are crazy!! I cover the bar but the tiles come loose and fall off anyway. I've tried all the glues and grout and plaster type things I can think of.
Old 05-05-2013, 02:44 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
do you have freezing temperatures? do the tiles come off in whole or broken?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-05-2013, 02:52 PM   #6
if you're located in a freeze/thaw clime, tile's never recommended,,, expansion/contraction & wtr in the mud/grout will work against you,,, wrong mtls/method for the task @ hand
Old 05-06-2013, 04:11 PM   #7
Rewards Points: 254
What are the tiles bonded directly to? wood? Try a exterior plywood base then cover it with cement board- tape any gaps and apply Hydroban or Redguard ( 2-3 coats). Then thinset your tiles on ( not the premixed crap). They also make color matched 100% silicone that is sanded that you could try and use as grout which would allow for movement but is a chore applying and smoothing it out but might help in your cold area.
pwgsx is offline   Reply With Quote
The Following User Says Thank You to pwgsx For This Useful Post:
oh'mike (05-07-2013)
Replacing 2 ceramic tiles over Ditra RichardZ Flooring 33 01-17-2013 01:22 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 09:40 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
