Tile Free Concrete/mortar Shower Surround - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-28-2012, 08:00 AM   #1
baandla's Avatar
Lightbulb
tile free concrete/mortar shower surround
So, I have been attempting to do research on doing a polished concrete look shower surround. All I've been able to find is you CAN'T do this and you CAN'T do that and just slap some tile on it(apparently tile cures the common cold}. Well it's hard for me to subscribe to a CAN'T do philosophy when I've seen "concrete" showers, pictures of "concrete" showers, and when goggled there are plenty of companies that do "concrete" showers. From what I've been able to gather and my inclination to think outside the box, my theory on how this CAN be accomplished is as follows:
-Hardiebacker cement board attached to studs with cement board screws
-cement board mesh tape attached to seams
-seams and screws troweled with flexbond crack prevention thinset mortar
-sand thinset down smooth
-coat entire surface with Redgard crack prevention and waterproofing membrane
-trowel entire surface with flexbond thinset mortar(mixed with sakrete brown cement dye)
-screen/sand surface down as smooth as possible
-trowel Henry Feather Finish(skim coat) over thinset(mixed with brown cement dye)
-sand down as smooth as possible
-apply Miracle Sealants 511 impregnator
-apply a concrete/cement polish of some sort(Eagle gloss concrete polish or Miracle Sealants stone polish, etc}
-buff
*sidenotes: -yes, I know the difference between concrete and mortar
-what the manufacturers cover our *ss warranty covers is
of little concern to me
So, Ive read plenty of forums, etc... about how this CAN'T be done. I'd like to know how this CAN be done with the highest probability of success. Any thoughts, suggestions, etc, would be greatly appreciated.
Thanks in advance
“Learning and innovation go hand in hand. The arrogance of success is to think that what you did yesterday will be sufficient for tomorrow.”
William Pollard
baandla is offline   Reply With Quote
Old 11-28-2012, 09:25 AM   #2
Rewards Points: 1,232
I think you have the backing and waterproofing figured out pretty well, but I do not think that the Henry material will make a good finish. A product closer to pool plaster would work better as a final coat, but I also think you need a couple of coats under that of a polymer modified cementious stucco, aiming for a final thickness of 1/2-5/8". Every right angle is also going to crack, so you may also consider coving them out at least 3/4".
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-28-2012, 04:39 PM   #3
baandla's Avatar
thank you for the advice, i will definately add that to my to do list
URGENT!need to find the order of putting in a tile shower gailquiler3 Plumbing 6 11-19-2012 08:10 AM
Crack in old shower tile Jeff DIY Flooring 21 01-15-2012 02:11 PM
Tile shower surround above fiberglass shower Gregghea Tiling, ceramics, marble 3 01-28-2011 07:39 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Tub surround golfer2b Flooring 26 08-30-2008 12:25 PM
