Thinset On Fake Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-06-2012, 07:22 PM   #1
Thinset on Fake Stone
Hi all,
Searched for this for ages online before posting a question here. I want to set a few Culture Stone on Durock on an interior wall and I've read here - most notably from Tscarborough - that one can use a thin set to fix them on an interior application.
My question, which doesn't seem to be answered is how thick to put on that thin set - 1/4" trowel and butter the backs? Bigger toothed trowel? Those cultured stones are pretty uneven things so you're going to need some thickness to the thin set which may well get pricey.
Thanks,
Dave
white_wulff is offline   Reply With Quote
Old 11-06-2012, 07:35 PM   #2
DIY staff
Rewards Points: 7,174
Have you looked at any instructions from the fake stone maker?
I would think that back buttering would be needed---I've never set that product----
Thinset is about the cheapest stick um available----be glad they don't all for a bucket mastic--that would be expensive.
Old 11-07-2012, 09:37 PM   #3
Rewards Points: 1,230
You need enough, backbuttered, so that when you press hard, you barely feel the fake stone touch if at all. You may need to knock off the high points on the back. Do 100% coverage on the back of the stone, then run your trowel down the middle to provide some room to compress the mortar to allow for setting the stone.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
2" Hole in Fake Stone? DWooderson Concrete, Stone & Masonry 3 10-01-2012 02:58 PM
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate? Minich Remodeling 8 02-01-2012 09:27 AM
Cultured Stone - Mortar or Thinset? JackOfAllTrades Building & Construction 6 11-03-2009 04:55 AM
