Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-05-2012, 10:49 AM   #1
Thin Brick Question
A military friend indicated he installed thin brick a few houses ago and instead of using the traditional lath with a scratch coat he used some sort of panels that had "fingers" that held the bricks in place. He indicated each thin brick had approximately six fingers holding it in place and that the trick was installing the panels correctly but once that was done all one had to accomplish was placing the bricks in place and then applying mortar between the joints. Does anyone know what this system is? Thank you.
riddlers is offline   Reply With Quote
Old 10-05-2012, 10:22 PM   #2
Thin Brick Question
That would be the Glen-Gery Dept. of Defense thin brick system.
cleveman is offline   Reply With Quote
Old 10-05-2012, 10:42 PM   #3
Thin Brick Question
looks something like this
epson is offline   Reply With Quote
Old 10-06-2012, 06:51 AM   #4
Thin Brick Question
I want to ensure the serious and true answer exists for those looking at installing thin brick. Located the information, or one manufacturer of a system at the following link:
http://www.tabswallsystems.com/
Another system is located at the following link, but one should note that if you use that system you must also purchase only their bricks:
http://www.redlandbrick.com/thinbrick.asp
This company also requires a minimum order and it proves extremely expensive.
question about brick patio base vipergtsxz Landscaping & Lawn Care 5 06-30-2012 03:17 PM
question about an old brick chimney DIherself Roofing 1 04-28-2011 12:16 AM
Potential foundation issues oklahomaguy32 General Discussion 7 02-14-2010 04:12 PM
Reusing old brick for a shop bigalpha Building & Construction 12 01-20-2010 08:59 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
