I came across a load of brick the previous owner left behind. Only thing is these bricks are about half the thickness of a normal brick. I am thinking about making a very small patio space out in the yard with them. Just big enough to hold two chairs and a small table. If i do the prep right will it work with these bricks?
Your have to find out if these are paver bricks or faux wall bricks which is more likly.
There useless for a patio in most cases and would need to be laid over a concrete slab.
I am in a similar situation. I have a bunch of thin brick pavers, I pulled some of them up and want to relocate to an area where I can make a nicer patio space to fit a couple lounges and small table. I picked up some decomposed granite and was going to level off my area and put some of it down as a base for my brick patio. Am I going in the right direction, should I not use decomposed granite?
You can see the bricks here on the right and the decomposed granite in the bucks.
As you can see I have never done this before and don't really know anything about it. thank you so much in advance for the help.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
