-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Thin Brick Patio? (http://www.diychatroom.com/f105/thin-brick-patio-136740/)
asbury park 03-11-2012 08:05 PM
Thin Brick Patio?
I came across a load of brick the previous owner left behind. Only thing is these bricks are about half the thickness of a normal brick. I am thinking about making a very small patio space out in the yard with them. Just big enough to hold two chairs and a small table. If i do the prep right will it work with these bricks?
joecaption 03-11-2012 08:34 PM
Your have to find out if these are paver bricks or faux wall bricks which is more likly.
There useless for a patio in most cases and would need to be laid over a concrete slab.
asbury park 03-11-2012 08:45 PM
Well, I pulled up a lot of them from a walkway that was in the yard. Pretty sure they are pavers.
concretemasonry 03-11-2012 08:51 PM
Just measure them and determine if they are thick enough to use without spending a bundle on an adequate base. the odds are against using them.
Dick
jomama45 03-11-2012 09:22 PM
They sound like "split pavers" and are likely 1 1/8" to 1 1/4" thick.
If you set them on an adequate base, they should hold up OK to regular foot traffic.
asbury park 03-12-2012 04:52 PM
1 Attachment(s)
Here are the bricks
hakunatata 05-05-2014 02:56 PM
how did the walkway turn out?
I am in a similar situation. I have a bunch of thin brick pavers, I pulled some of them up and want to relocate to an area where I can make a nicer patio space to fit a couple lounges and small table. I picked up some decomposed granite and was going to level off my area and put some of it down as a base for my brick patio. Am I going in the right direction, should I not use decomposed granite?
https://lh3.googleusercontent.com/-_...2/ZOE_0011.jpg
You can see the bricks here on the right and the decomposed granite in the bucks.
As you can see I have never done this before and don't really know anything about it. thank you so much in advance for the help.
