Taping Trash Bag To End Of Sonotube - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-05-2013, 11:30 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Taping trash bag to end of Sonotube
I read an user tip, I think it was in Fine Homebuilding magazine, where he tapes a trash bag to the bottom of the sonotube. The idea is to expand the bottom of the hole so that it's larger than the sonotube and when you start filling the tube with concrete, the bottom will fill to the entire width of the hole without spilling out and up the hole. Is this considered a good idea?
Or is there some reason that the concrete needs to be directly on earth?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-05-2013, 03:14 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
that's a new one on me ..... it would only expand out if the tube is set above the bottom of the hole, or maybe my brain's not working
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-05-2013, 03:18 PM   #3
I have gas!
That's it exactly. As you know, here in MA we have to dig 48" down but the length on the Sonotube is 48", so to get it above grade you have to pull the tube up a few inches anyway or tape an extension on it.
Old 09-05-2013, 03:19 PM   #4
GBrackins's Avatar
you'll have to let us know how it work if you try it out
Gary
Old 09-05-2013, 04:10 PM   #5
Rewards Points: 3,834
I doubt it would help in a shallow hole of 4 ft.depth,belling a caisson is usually done at the depth of hard pan or bed rock to add stability,and the bell is usually 3 times the size of the shaft.
http://www.google.com/imgres?imgurl=...QEwBA&dur=8913
Canarywood1 is offline   Reply With Quote
Old 09-05-2013, 05:26 PM   #6
I have gas!
I think you're right, it a real PIA to get the tube plumb in the hole where it's not sitting on the bottom. I've been scratching my head as to how to get the tube set with this method. I built a jig but it doesn't hang on to the tube tight enough without changing the shape of the tube. I think for the holes where I belled the bottom, I'm just going to throw in 6" of concrete then put the tube on top, add 4 sticks of rebar, and then fill around it before adding the rest of the concrete.
Old 09-05-2013, 05:29 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 922
Why not get longer tube? I know it's available
Old 09-05-2013, 05:36 PM   #8
Rewards Points: 2,652
Might be better off with a bigfoot. Gotta dig a pretty big hole though.
SPS-1 is offline   Reply With Quote
Old 09-05-2013, 05:36 PM   #9
I have gas!
The big box stores only carry 48" tubes. I'm not sure the lumber yards would have different. I have 8 piers to pour tomorrow, so that would be 1 sacrificial tube to get all 6" above grade.
No need for big foot. I checked with the building inspector, he said even with my 10" form, my spec'ed 4000 lbs of load is nothing for the soil conditions.
Old 09-05-2013, 05:44 PM   #10
Plumber
Rewards Points: 922
They make them longer. How do you think they pour columns and such?
check your local yards or concrete suppliers.
I suppose the bag would work too. As a youngster I worked concrete. We poured interior footing pads in corrugated cardboard forms- had to be gentle and use a stiff slump, but it worked- most of the time
Old 09-05-2013, 06:10 PM   #11
I have gas!
I don't know what I was thinking, I thought it would be relatively easy to build a jig to hold these up while I poured the cement. In practice, it didn't work out that way. Oh well.
Old 09-05-2013, 06:16 PM   #12
What if you cut part off the bottom, almost like a scalloped shape or castle-wall? That way, you have even points of contact at bottom of hole, the concrete can flow out the cutouts, and no jig needed
mterry is offline   Reply With Quote
Old 09-05-2013, 07:06 PM   #13
GBrackins's Avatar
well he'd certainly know the soils in that area better than I, but a 10" sonotube has 0.55 s.f. of bearing area. 4000 lbs load over that area requires at least 7400 psf soil bearing capacity.
Myself I would have specified a 24" Bigfoot for the 4000 lb load. If I do not have a soil test to go by I use 1500 psf as my soil bearing capacity and figure my footing based upon the load. I tend to be conservative, keeps me out of trouble.
Gary
Old 09-05-2013, 07:29 PM   #14
I have gas!
I think it's (from the code book) "Slightly cemented sand" and ledge; about 8-10 tons.
All I know the first 36" took about 15 minutes, the next 6" about 20 minutes and the last 6 inches about an hour and a half with a san angelo bar to break it up and a shop vac to get it out of the hole.
The inspector wasn't concerned at all.
Old 09-05-2013, 07:30 PM   #15
No, I think they got it right. They only need 910 psf soil capacity.
.55 sq ft x 910 psf x 8 footings = 4000 pounds.
sonotube how to EPERRINGTON Building & Construction 4 05-23-2011 08:19 PM
Sonotube size? MarcHRob Building & Construction 2 05-23-2010 10:15 PM
Taping suggestions misfitz Painting 1 07-02-2009 07:26 AM
Tiling on cardboard tube (sonotube) DeFex Tiling, ceramics, marble 7 05-20-2009 03:17 PM
Wavy taping seams - Help (drywall taping) newbpainter Drywall & Plaster 10 05-15-2009 09:36 AM
