Tapcons Not Grabbing Cinder Block - Concrete, Stone & Masonry - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-02-2014, 04:31 PM   #31
Rewards Points: 205
I have used tapcons in block successfully. I have also used tapcons unsuccessfully in block.
Here's a question. If I were to use the anchors that are hammered in with a shield, what's the procedure for removing them if necessary?
Thanks. I like the idea of using the wire in the hole. I have used two part putty in larger holes with tapcons and after it cures it is rock solid.
CosmicMiami is offline   Reply With Quote
Old 01-02-2014, 04:46 PM   #32
Rewards Points: 4,640
you install the lead shields in the proper size hole - place whatever must be attached - start screwing in the lag,,, NEVER hammer in the lag already inserted into the shield,,, to remove, reverse procedure - screw the lag OUT,,, don't expect to save the shield, tho
tapcons in CINDER block will fail more often that they'll work successfully
2part epoxy putty + a tapcon ? that's like suspenders & 2 belts, no ?
Old 01-02-2014, 06:15 PM   #33
Rewards Points: 205
I know that. I was referring to the one that is hammered in.
I've done this in block when the tapcon doesn't hold snug and it works great for hanging stuff like hose reels and such on my house. Most all the construction here (see my name) is CBS. But yes, it does seem a little redundant. I would use something a little more substantial for things that carry a bigger load.
Old 01-02-2014, 06:35 PM   #34
joed's Avatar
Rewards Points: 12,852
Any anchor used in concrete should be considered permanent instal.
Old 01-02-2014, 10:56 PM   #35
Rewards Points: 172
In the end....I used the redheads. I could only find them up to 3 inches in depth, but it was just enough to hold real nice. It only requires to be 3/4 of an inch to be embedded into the block and I had about an inch going in. Thanks for all advice.
nateshirk is offline   Reply With Quote
Help with a Fence to Cinder Block Wall avandelay Carpentry 7 08-30-2013 09:17 AM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
