Tapcons Not Grabbing Cinder Block - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-18-2013, 06:12 AM   #16
Rewards Points: 4,726
IF they're cinder blocks, tapcons won't work,,, i'd probably use hardened conc nails & pl adhesive
The Following User Says Thank You to stadry For This Useful Post:
concretemasonry (12-27-2013)
Old 12-18-2013, 07:56 AM   #17
Rewards Points: 13,960
The wood should not be attached directly out to the concrete.
You should be building a 2 X 4 wall out away from the block.
Some reasons why:
How would you install boxes and run the wiring?
There will be no thermal break.
They may rot due to moisture.
Old 12-18-2013, 09:03 AM   #18
Rewards Points: 2,516
Originally Posted by danpik View Post
Also, you need to make sure you are drilling straight into the hole and not moving the bit around as you drill.
I agree with danpik. Method of setting tapcons even into hollow block is important. First and foremost when drilling, make sure you do not let the bit walk around the hole. Clean the hole out of dust before inserting the anchor and when setting the anchor dont let it turn too fast or overtorque it.
Here are some other fastening options.
hammerlane is offline   Reply With Quote
Old 12-18-2013, 09:13 AM   #19
Some reasons why:
+1 on all of this!
You only need about an inch or so between the back side of the 2x4 wall and the existing masonry wall.
jponto07 is offline   Reply With Quote
Old 12-18-2013, 12:28 PM   #20
Rewards Points: 1,010
Originally Posted by nateshirk View Post
Why do threads go so far off track? Can I just get some good, solid ideas on how to secure some lumber to a block wall?
Substitue the "internet" for "Chinatown". It's just the way it is. You get what you pay for.
Anti-wingnut is offline   Reply With Quote
Old 12-18-2013, 12:36 PM   #21
Rewards Points: 172
As I already said, the moisture is taken care of. I'm not asking how to build a wall. I cannot build it thick enough to frame a normal 2x4 wall. 2" Foam is going down first, except under the wood. A 1/2 inch piece of foam is going under the 2x3, so it all sits flush.
I'm drilling straight through the block. Nothing should be sitting in the hole. I'm not reeming it. I take the tapcon and screw it in, not fast or slow. It just spins straight through, and never even tries to grab the block.
nateshirk is offline   Reply With Quote
Old 12-18-2013, 12:45 PM   #22
I'd use this:
http://www.clarkdietrich.com/product...urring-channel
And attach with these:
http://www.fastenal.com/web/products/details/50505
Old 12-18-2013, 12:45 PM   #23
A 3/16" tapcon should be using a 5/32" bit for its hole. Verify your bit is 5/32
The Following User Says Thank You to hammerlane For This Useful Post:
jomama45 (12-19-2013)
Old 12-18-2013, 12:49 PM   #24
Either your block is exceptionally brittle and crumbling as you are drilling, your bit is bent causing it to open the hole wider than the bit itself or you aren't holding the drill as steady as you thought. Otherwise, your hole would be okay.
Just out of curiosity, what kind of drill and bit are you using?
Old 12-18-2013, 02:52 PM   #25
Rewards Points: 392
Forget Tapcons in "cinder" block, ain't happening with any degree of comfort. The hammer type ones Anti showed sometimes work. I'd try the double cinch expansion or a toggle, forget sleeve anchors and powder actuated fasteners too. Cinder block is the worst material to fasten too, been down that road.
rustyjames is offline   Reply With Quote
Old 12-18-2013, 05:48 PM   #26
GUYS !!!!!!!!!!!! they're cinder ' according to the op,,, not even as strong as conc blocks,,, maybe not all that many have ever seen a cinder block IF the op needs, use a toggle - use a conc nail & pl, use the conc floor & brace the other end against a top place nailed to the ceiling joists,,, hasn't enough bee said by now ? somehow i think most of us wouldda had the *^$#@%*)^&$# 2c4's in already
The Following 2 Users Say Thank You to stadry For This Useful Post:
bob22 (12-23-2013), concretemasonry (12-18-2013)
Old 12-20-2013, 11:28 AM   #27
Rewards Points: 582
You may be able to use the dot and dab method with insulated plasterboard.
http://www.ecotherm.co.uk/our_produc...eco-liner.aspx
stuart45 is offline   Reply With Quote
Old 12-27-2013, 11:22 AM   #28
Rewards Points: 209
Scroll up to the pictures posted above. See the expansion anchors. Purchase some. They are excellent for cinder blocks.
ChantryOntario is offline   Reply With Quote
Old 12-27-2013, 12:23 PM   #29
concretemasonry's Avatar
Rewards Points: 2,626
Unfortunately, few people know what a "cinder block" is and they think any block of concrete with cores (1, 2 or 3) is a cinder block, but by code it is a "concrete block" and may use actual cinders (waste product or natural cinders). The most common cinders are only found near/around old railroad lines and near some older industrial plants. - They are highly variable waste products with different properties, so only trial and error would be the best method. Real "cinder block" from 40 miles away may be totally different.
Actual concrete block are much different and the better ones are made from naturally created lightweight aggregate and are more costly and are not used for low cost uses. Natural cinders are sometimes used in architectural block and are very pricy and have good properties and uniformity.
Dick
concretemasonry is offline   Reply With Quote
Old 12-27-2013, 05:04 PM   #30
Ole Wood Worker
BigJim's Avatar
Rewards Points: 494
If you have screws that just spin in the hole, I find this works for me, and you can bury the screw head in the wood. Cut a length of 12/2 WG romax electrical wire about 6 inches or so long. Strip the outside insulation where you have three individual wires but leave the plastic on the individual wires. Insert one wire into the hole you drilled and bend back about 1/2 inch of the wire outside of the hole so it won't fall through. Just screw the screw in and it will hold. It has always worked for me.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Help with a Fence to Cinder Block Wall avandelay Carpentry 7 08-30-2013 09:17 AM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
