Tapcons Not Grabbing Cinder Block - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-16-2013, 04:09 PM   #1
Rewards Points: 172
Tapcons not grabbing cinder block
I'm using 3/16"x 2-3/4" tapcons through a 2x3 and into cinder block. I'm using the bit that came with them (which seems a tad too big). They don't even start to grab. They just spin. Could the bit be too big? Would a bigger tapcon help, or would that crumble the block too?
nateshirk is offline   Reply With Quote
Old 12-16-2013, 04:40 PM   #2
Rewards Points: 14,026
May want to share what it is your trying to do.
Any wood in contact with a block wall needed to be pressure treated.
I try to hit the mortar not the block and mostly use the 1/4 screws and always predrill the wood for a clearance hole in the wood.
If there's no predrilled hole the screw tries to push the wood away from the wall.
Old 12-16-2013, 04:41 PM   #3
Rewards Points: 4,752
tapcons are for conc, not ' cinder block ',,, don't expect much pullout strength & expect reduced shear strength,,, those blocks have little strength other'n compressive strength ( holding up weight such as a house ! )
depending on your task, you may wish to attach a 2x4 supported by the conc floor using lead shield lags just to stabilize the 2x4
Old 12-16-2013, 04:50 PM   #4
concretemasonry's Avatar
Rewards Points: 2,626
There is a falicy about not having untreated wood in contact.
The actual requirement only applies to concrete that is in contact with the soil or actual water. It is allowed in masonry cavity walls above grade and is used on many high rise concrete structures.
It just takes a little common sense and not a blanket standard.
Dick
concretemasonry is offline   Reply With Quote
Old 12-16-2013, 05:18 PM   #5
joed's Avatar
Rewards Points: 13,368
Definitely sounds like the holes are too big.I have successfully used tapcons into concrete blocks many times. The blocks are harder than the mortar and give better results in my experience.
Old 12-16-2013, 05:24 PM   #6
Rewards Points: 582
you will be disapointed when using tapcons on cinder block....won't hold ..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
joecaption (12-16-2013)
Old 12-16-2013, 05:30 PM   #7
The strength of block can vary widely since the standards (ASTM, etc.) are so low. For a good manufacturer, the strength is not a problem and they usually about 30% to 50% over the minimums because it actually is more costly to make a weak block. Water (not cement) is cheapest way to make a stronger block, but a good contractor will not accept that because dimension uniformity is the way to get economical walls.
Usually, the aggregate gradation will control the ability to hold a threaded anchor. Some aggregate types are better than others, but few block are made for nailing into.
Dick
Old 12-16-2013, 05:45 PM   #8
Rewards Points: 1,300
danpik is offline   Reply With Quote
Old 12-16-2013, 10:44 PM   #9
Rewards Points: 172
Why do threads go so far off track? Can I just get some good, solid ideas on how to secure some lumber to a block wall?
Old 12-17-2013, 12:48 AM   #10
Oso954's Avatar
Rewards Points: 1,354
You might want to mention why you are trying to attach them. Hanging tools, putting up dry wall, building shelves for heavy weights, etc.
It might make a difference.
Oso954 is online now   Reply With Quote
Old 12-17-2013, 01:55 AM   #11
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I gave up trying to use tapcons, I find they're too hit and miss. Some will grab but most wont.
Look at powder actuated tools, or even construction adhesive like PL premium. That stuff holds VERY well. Downside is it takes a while to cure so you can't exactly afix something and put weight on it right away, and as much as it does hold well I would not trust it for anything that has to hold people. (ex: if you have a very tall cinder block wall I would not make a second floor with only adhesive!) Then again I would not trust tapcons for that either...
For solid concrete I like to use wedge anchors. More expensive per unit than tapcons but they go in faster and hold much better.
Old 12-17-2013, 04:12 AM   #12
you're from philly, right ?,,, ' threads go so far off track? ,,,some good, solid ideas on how to secure some lumber to a block wall? ' gosh, thought we had list'd some good stuff lead shield lags, pl const adhesive,,, we forgot conc nails ( hardened steel ) & boogers then again, you never said what you were trying to accomplish
Old 12-17-2013, 05:44 AM   #13
It is called thread drift. Happens sometimes. I deleted the drift that I made. Sorry.
Old 12-17-2013, 05:49 AM   #14
something to understand about tapcons. The method and tools used to drill the hole are important. If you have a slow drill or a dull bit the extra time the bit stays in the hole actually can make it bigger from the erosion of the dust working its way out of the hole. Also, you need to make sure you are drilling straight into the hole and not moving the bit around as you drill. Setting the screw is equally important when it comes to the proper tool. I can never get a screw to hold properly if I use a slow speed driver. I found my Makita Screw gun to work best. If you use a slow speed drill or cordless, it can cause the screw to act as a drill bit and ream out the hole as it goes in.
Old 12-18-2013, 06:05 AM   #15
Rewards Points: 172
I will be securing drywall to the 2x3's. I need something that will sit flush or below the wood. I know.....the moisture is already taken care of. I just figured if I mentioned that I need something to do the job that a tapcon should be doing, that would be all the info needed.
Help with a Fence to Cinder Block Wall avandelay Carpentry 7 08-30-2013 09:17 AM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
