Tamping Concrete Pavers - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-05-2013, 11:31 AM   #1
Rewards Points: 121
Tamping concrete pavers
I am setting pavers in an area that is too confined to use a plate compactor/vibrator. I have a 10" x 10" hand tamper that I used to compact the base/gravel. How do I protect the pavers from damage if I use this for the final compaction?
jrepp44 is offline   Reply With Quote
Old 08-05-2013, 01:34 PM   #2
Rewards Points: 1,294
I had to do the same thing several years ago. I folded a couple of old bath towels, set the tamper on it and folded the edges of the towels over the top and taped them in place. Was able to do all of the tight areas with no problems.
danpik is offline   Reply With Quote
Old 08-05-2013, 02:36 PM   #3
concretemasonry's Avatar
Rewards Points: 2,566
It really depends on the type of pavers.
If you use the large (over 10"), then they are just "stepping stones" and rely on the strength of the base, then "tamper" with some force and weight will be adequate.
If they are the common smaller pavers set on a 1" sand bed that rely on an interlock (usually a thin amount of sand between the butted pavers) between units for strength and stability. A vibratory plate compactor will give the truest surface and the most strength and stability, just as they do on driveways and streets, etc.
Dick
concretemasonry is offline   Reply With Quote
Old 10-24-2013, 11:37 PM   #4
I've just completed building a 7'x7' sitting area and a 15' walkway to it, using left over pavers from a patio reconstruction years ago. I used a hand tamper to compact the base, screed the result to get the drainage grade I wanted, and gently tamped the result.
Then I placed the pavers on the base, and used a short 2x4 and a dead blow hammer to insure there were no high spots. Then, before cementing the edges, I poured polymetric sand over the pavers, swept it into all the cracks, and gently tapped each paver several times with the dead blow hammer to insure the sand had settled. Finally, wet the sand, let it dry, and used Portland cement on all edges.
Using a hand tamper and a dead blow hammer was a pain the in butt, even for a small job, but the results are rock solid.
szn8t4 is offline   Reply With Quote
Travertine pavers driveway in cold climate Leopro Concrete, Stone & Masonry 7 01-05-2013 12:06 AM
Pavers over concrete & grass? katkins0027 Landscaping & Lawn Care 2 05-18-2012 10:37 PM
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 06:45 PM
concrete under pavers around pool deck , pavers go to edge of pool doggie44 Landscaping & Lawn Care 0 02-27-2011 11:40 AM
Concrete or Pavers ? mikesenior Landscaping & Lawn Care 4 05-02-2010 04:19 PM
