Synthetic Stone Over Precast Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-30-2012, 08:42 PM   #1
Synthetic stone over precast concrete
I have precast basement walls and I'm questioning whether or not any special pre-treatment is required over the precast concrete such as water blasting, sand blasting or acid etching. I intend to ask the wall manufacturer but for several reasons I don't put much faith in their advise. I am also wondering if it is okay to run the stone to or just below finished grade. We did that on my detached garage with no ill effects after one Buffalo, NY winter. No brick ledge was used and the stone was placed with a scratch coat over a poured concrete wall. I want to do the same thing to my new house with the precast walls. Thanks
dpdrive is offline   Reply With Quote
Old 03-31-2012, 11:11 AM   #2
Rewards Points: 1,232
If they are fresh, they may have form release on them. A good quality polymer modified thinset is what I have used, unless you want to lath it.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 04-10-2012, 08:50 PM   #3
Rewards Points: 152
Easy rule of thumb. Masonry bonds to masonry. Scratch coat, then stick stone. If you have any worries, use type M mortar, the highest strength available without additives. Good to go = )
TRUEPRO is offline   Reply With Quote
Old 04-10-2012, 09:28 PM   #4
concretemasonry's Avatar
Rewards Points: 2,608
Truepro -
A high strength mortar is the last thing to use since it has a high compressive strength (not needed here) and does not have the other desired properties that Types N and S have for a veneer (non load bearing) type application. Stronger or bigger and heavier is only good for dumb work where a sledge hammer is used.
Thinset or a polymer in the mortar is best to insure a good bond.
Precast concrete is NOT masonry.
Dick
concretemasonry is offline   Reply With Quote
Old 04-11-2012, 05:48 AM   #5
Rewards Points: 4,656
what dick & t-scar said !
& in buffalo, depending on the individual stone's weight, i'd be adding mechanical anchors & applying silicone siloxane when done - or, at least, that's what i'd be doing if back home in binghamton - good luck !
Old 04-11-2012, 09:12 AM   #6
Rewards Points: 152
Dick,
Does mortar not bond to precast? When i say that masonry bonds to masonry im referring to any porous surface (brick wall, block wall, concrete wall) that stone and mortar could be applied to. Yes, you can stick stone on precast i do it all the time. And who in the world would use thinset to apply stone veneer? Yes i agree its very doable but that not common practice AT ALL. I feel bad for the user who wanted some solid advice cause now you have complicated things by suggesting all these additives blah blah blah. Its a simple project that does not need to be overkilled. Thanks for the input dick.
Old 04-11-2012, 09:42 AM   #7
Concrete & Masonry
Rewards Points: 582
Do not use Type M, it's far too strong for this application, as stated by others above.
A few ounces of bonding agent per batch will go a long way, and will work far better than additional, un-needed Portland cement....
jomama45 is offline   Reply With Quote
Old 04-11-2012, 12:42 PM   #8
High strength mortars (Type M) do not have properties necessary to bond properly that the lower strength mortars do, so often additives (bonding agents) are necessary - blah-blah-blah.
In the Buffalo location, it could be a "superior" foundation with little horizontal continuity on a gravel foundation and high density/low absorption concrete panels that present bonding and adhering problems and cracking possibilities. If it is a series of larger (wider) garden variety precast slabs placed on a concrete footing, the concrete is usually not a dense, is easier to bond to and cracking possibilities due to the shadowing of the panel joints to the surface exist.
It never hurts to improve the bond by using the right type of mortar and cheap additives for exterior applications that can be hard to repair.
Dick
Old 04-11-2012, 03:23 PM   #9
you looked better when you posted a picture of your wife's car, the bugatti veyron
Old 04-11-2012, 04:33 PM   #10
That car was the one I sold before marrying my first wife (Joy1) of 25 years. My second wife (Joy2) of 22 years drive a Blazer almost identical to my Jimmy. Joy1 and Joy2 are great friends and control the family social matters and menus.
I do enjoy cars, but drive what works best for me. With my Jimmy, I can go cross country after a good dirt track race or can tailagate after a good road race (deinitely not NASCAR tank racing).
Since we are getting into the fishing season, I will use my trophy fish avatar soon.
Dick
Old 04-12-2012, 08:40 PM   #11
Concrete & Masonry
Rewards Points: 582
Dick
Do you ever get a chance to get to Cedar Lake by chance??
Tags
concrete , precast , stone , veneer
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
Prep Concrete Block Wall for Natural Stone Veneer SCPete Building & Construction 2 03-06-2011 11:19 AM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 06:52 AM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 03:49 PM
