Synthetic Concrete Mix? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-04-2013, 09:44 PM   #16
Guywithskills
I have posted on this before, the patches and mixes are ok for temporary. they are not a permanent fix. Do the temporary now and repour it when it warms up. Cement should not freeze for minimum 48 hrs and preferably 7 days for initial cure. After the repour, use a concrete sealer that "gels" the surface. this is a spec product that can only be found at a place like Border Products... it will keep the water from penetrating the surface finish. It is supposed to cause the finished concrete to gel and making a water resist barrier. We used this stuff in Walk In freezers to protect the finish.
Guywithskills is offline   Reply With Quote
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 04:15 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
