Sweating Slab Should I Resurface? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-15-2014, 08:00 AM   #1
Sweating Slab should I resurface?
I have an elevated beach house that has a concrete slab under the house. The slab has what looks like a shiny coating on it, like some sort of sealer. When it is very humid (which is always during the summer in eastern NC) the slab gets wet and the the coating makes it very slippery. I notice that my neighbor's slab has more of a normal look and feel of concrete and when mine is wet, theirs is dry so I assume it is the coating that is causing mine to be wet.
I was at Home Depot yesterday and I saw that they rent what looks like a floor buffer that basically takes the finish off of concrete. I'm wondering if that will work in my situation. My questions are:
1. Does it sound like this coating is causing my sweating problem?
2. It is advisable to use the buffer and remove the coating?
3. If I do remove the coating should I reseal and if so with what type of sealer so this doesn't happen again.
diverdave is offline   Reply With Quote
Old 06-15-2014, 04:01 PM   #2
Rewards Points: 4,656
they've got 2 ' wheels ' that fit on a lo-rpm buffer,,, get the 1 w/diamond-tipped fingers & run it wet ( wtr on the conc ),,, run it dry & you'll buy it,,, once you get what sealer off that you can, don't reseal
irc
sunken sidewalk to raise D270 Concrete, Stone & Masonry 6 11-02-2013 11:52 AM
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 11:16 AM
raised slab foundation tclark Building & Construction 6 01-07-2011 08:10 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
