Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-11-2012, 01:07 AM   #1
Student that needs help
Hi everyone.. I'm a Construction Student and I have been stuck on this problem
for two days now.. I'm currently learning how to calculate blocks and rebar.
Now we moved to labor hours.
I read the book back and forth and does not give me the formula to figure it out,.
The question on my homework is:
Determine the cost of the Lay of CMU Blocks
and the Labor Hours.
The SF is 1386.64SF
8.5 labor hours per 100sf of wall is $21.03
6 mason hour per 100sf of wall $42.00
Any help would so Tremendously appreciated!!
Thank you
Cali
calialexandra is offline   Reply With Quote
Old 12-11-2012, 03:15 AM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
From the information you provided I can only assume that the formula would be something like this:
(8.5 x $21.03 = $178.76) per 100 sq. ft. of wall + (6 x $42.00 = $252.00) per 100 sq. ft. of wall.
$178.76 + $252.00 = $430.76 per 100 sq. ft. of wall
You have 13.8664 (100 sq. ft. sections of wall)
so...$430.76 x 13.8664 = $5973.09 in labor costs.
Sound right?
Andy.
Residential Drafter/Designer
AndyGump is offline   Reply With Quote
Old 12-11-2012, 09:07 AM   #3
let me add if your labor costs are that high, you won't be getting any work this is an arithmetic problem, nothing else
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 12-11-2012, 11:35 AM   #4
That is low for this area, closer to $10,000 for that SqFt, but as noted it is just an arithmetic question.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Job Corps Student BigGuy01 Introductions 3 07-21-2011 11:44 PM
power tool student survey kjkreuter Tools 7 03-09-2011 07:07 PM
student who needs help awstudent Off Topic 2 04-26-2010 07:16 PM
