Stuccoing A Patch- What Do They Call It? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-19-2012, 03:34 PM   #1
Rewards Points: 1,062
stuccoing a patch- what do they call it?
People,
I seem to remember years ago, when I did a stucco patch on ext of house, youre supposed to buy one kind of mix for the 1st scratch coat, then a 2nd type for the finish stucco surface. Am I right? HD says they have one kind that is suitable for both finishes.
Why am I thinking the finish mix has a different name(?). Also, 80lb bag seems to be typical of this product. Man, thats heavy......LOL
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 05-20-2012, 05:49 AM   #2
Rewards Points: 582
Normally the sratch coat should be stronger than the top.
A typical mix would be 1/1/4 lime/OPC/sand for the scratch and 1/1/5 for the top, although some plasterers prefer 1/1/5 and 1/1/6.
I think in the USA the base is known as the brown coat, and the top as the colour coat, but I'm not 100% sure.
Cement bags used to be 112 lbs here, but EU regs now mean that 25 KGs is the limit.
stuart45 is offline   Reply With Quote
Old 05-20-2012, 07:33 PM   #3
Thanks, Stuart! Geez, 112lb!! Too heavy! Yes, I did learn they call it brown coat. I also heard sometimes 3 coats are required (final on top of brown coat).
Hurray for the EU! They have your health in mind! Sow, your boss says "go and get and carry TWO of the 25Kg bags......LOL
Old 05-20-2012, 11:10 PM   #4
Registered User
Rewards Points: 5,216
http://books.google.com/books?id=mFT...age&q=&f=false
Gary
Old 05-21-2012, 06:07 PM   #5
thanks, gbr. It shows 3 coats. Good to know.
Bad Roof Patch nolimitsgo Roofing/Siding 2 11-25-2011 08:04 AM
trying to patch flat roof - leak in seam Camera Roofing/Siding 2 11-02-2011 11:25 PM
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 05:05 PM
Drywall patch not flush with wall MRCook Drywall & Plaster 5 07-26-2011 06:12 PM
how to patch hole H.O.P. Drywall & Plaster 1 04-01-2011 06:22 PM
