Stucco Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-04-2013, 10:17 AM   #1
Rewards Points: 91
Stucco Repair
Not sure where to post this. So mods move if necessary.
i have a small "CBS" home. The exterior walls are cinder block with I imagine stucco on top. The finish is such that rather than being a flat stucco look there are what I would describe as peaks. Almost as if when the finish was applied the material was pulled out by a trowel.
I don't know if this makes sense. Imagine the peaks you see in freshly whipped cream. Sort of like sharp points to the finish. Like this but more pointy
http://3.bp.blogspot.com/-W9m5n-6B-_...cco+Finish.jpg
Anyway the original owners built a wooden decorative surround for the front door and it is rotting away.
I'd like to remove it but than I have smooth concrete block underneath.
Any idea how to duplicate the rough sharp peaked look to match the rest of the house.
The big box stores tried to sellme a spray can of "stucco" but I don'tsee how this will work.
Any thoughts?
drjay9051 is offline   Reply With Quote
Old 12-04-2013, 11:53 AM   #2
Rewards Points: 1,232
It is very hard to patch stucco and match a finish. Professionals seldom get it exactly right, but you can use plain old Type S mortar from the big box stores and play with it. It is a technique, try searching Youtube for "California drag", or "knockdown finish" to see how it is done.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 12-04-2013, 08:08 PM   #3
Rewards Points: 3,624
You would probably be better off replacing the surround,than trying to match the stucco as previous poster says,even pro's rarely get a match.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 12-05-2013, 07:35 AM   #4
Rewards Points: 91
Except for the fact the surround has the same finish as rest of house. I will weigh my options.
Thanks for the help
Stucco Patch and Paint Repair B Rich Painting 5 05-22-2013 07:38 AM
STUCCO Question GrandSportC3 Building & Construction 0 12-12-2010 08:06 AM
painting stucco sorta myself AdamBNYC Painting 1 08-16-2010 08:17 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
How do I repair large sections of stucco? Replacement Building & Construction 1 08-30-2009 12:02 AM
