Stucco On Poured Concrete Walls - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-10-2013, 05:29 PM   #1
Stucco on poured concrete walls
Have just finished hanging all the metal lath on my painted poured concrete walls. This is in my basement. The guy who will be doing my stucco said he will use only two coats, brown coat and finish coat. I have read that when applying stucco over lath you have to use three coats,scratch, brown,then finish. Any ideas? The walls are painted. They have a stamped brick pattern and there are voids that will need to be filled in.
bestways is offline   Reply With Quote
Old 10-11-2013, 12:56 PM   #2
Rewards Points: 1,232
2 coats should be fine for that application.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 10-11-2013, 02:32 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,142
In your case, 2 should be fine. I just had the stucco done on my house...the last coat is actually called a color coat and is really nothing more than about an 1/8" layer of stucco with the color applied.
I'm assuming he is going to give you a smooth finish....
Old 11-04-2013, 07:19 AM   #4
Okay. Base coat is done over lath. Looks good. In a couple areas I noticed it seemed to dry quicker. I noticed a horizontal stretch about two feet long that was lighter in color. When I tapped my finger nail it seemed to have a ting to it. Seems to have a void behind it. There are only a couple areas that seem to do this. Is this normal or should I have my stucco guy look at it before the finish coat.?
Old 11-04-2013, 07:22 AM   #5
JOATMON
ddawg16's Avatar
Unless you expect the wall to get a lot of abuse...I wouldn't worry about it. Your second coat is going to add more thickness...so I'm sure it will be plenty strong.
Old 11-25-2013, 01:25 PM   #6
Okay. Stucco is up and looks great. Next step is sealing. I would like to use a good penetrating sealer that will also breath. I've been looking and many of the breathable sealers say not recommend for below grade. Does this mean exterior below grade? Any recommendations?
Old 11-25-2013, 02:58 PM   #7
Rewards Points: 3,418
http://www.prosoco.com/Products/d113...e-b0006e080476
Canarywood1 is offline   Reply With Quote
Poured concrete slab is not hardening jruppert Concrete, Stone & Masonry 13 06-09-2013 10:33 PM
Concrete patio blocks the stucco weep screed..how to fix this? westernguy Concrete, Stone & Masonry 0 06-19-2012 05:59 PM
home-made ThermoMass concrete poured wall? jklingel Building & Construction 16 12-09-2010 09:06 PM
Poured concrete walls advice? blinkme323 Building & Construction 13 11-21-2010 05:06 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
