Stucco Mix For Masonry Emulation Over Plywood/mesh - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-26-2013, 03:16 PM   #1
Rewards Points: 1,062
stucco mix for masonry emulation over plywood/mesh
I had to close a gap between my entry door and the top of the openning so I inserted a wooden box intending to make it look as much as the surrounding masonry. I guess the route is to apply some kind of applicable stucco/mortar mix over this wire mesh I applied.
Should I mix my own mix with base ingredients (have experience with doing that for making numerous plaster repairs inside) or is it good to go with a standard ready mix from a big box store?
stucco mix for masonry emulation over plywood/mesh-forumrunner_20131026_151658.jpg
Old 10-26-2013, 03:20 PM   #2
Rewards Points: 13,274
Anyone else think there should have been tar paper before the wire mesh went on?
amakarevic (10-26-2013)
Old 10-26-2013, 05:24 PM   #3
Registered User
Rewards Points: 5,216
Yep, two layers then the screen; http://www.buildingscience.com/docum...4d76deb0384cc0
And caulk the wood perimeter. Cups up;http://www.mnlath-plaster.com/librar...Update2009.pdf
Stucco mixes; http://www.cement.org/stucco/faq_coats.asp
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 10-26-2013, 06:42 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
Yea....a little paper would be nice.....seeing how stucco is anything but water proof....
Here is what my house looked like prior to stucco being applied.
The Following User Says Thank You to ddawg16 For This Useful Post:
amakarevic (10-27-2013)
Old 10-27-2013, 02:37 PM   #5
Registered User
Nice! Is the bottom (only) window flange over the sticky wrap for drainage?
Gary
Old 10-27-2013, 02:52 PM   #6
JOATMON
ddawg16's Avatar
Gary
Yes....if anything, my windows are over flashed.....the window has a nailing flange....flashing installed before the window goes in....then the flange is caulked....then flashing at the bottom...then on the sides...then the top....
When the guys installed the paper...they lifted the top layer of the bottom flashing and put the paper under it.
Water is not going to get in.....
Gary in WA (10-28-2013)
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 07:23 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 06:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 01:22 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
