Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-14-2013, 09:10 AM   #1
Stucco on interior basement walls
I plan on putting masonry stucco on my interior basement wall. The walls are poured concrete that have a stamped brick look now. The plan is to attach metal lath using 1 1/4" tapcons and fender washers.
1- should I use the rolled lath or the sheets?
2- anybody know a good quality premix to use?
bestways is offline   Reply With Quote
Old 03-15-2013, 12:05 AM   #2
Are you sure you don't want to save some money and just put a brick veneer on it instead?
cleveman is offline   Reply With Quote
Old 03-15-2013, 07:23 AM   #3
Walls are painted with some paint starting to chip. I need to hang the lath regardless.
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 09:15 AM
Patching stucco to match existing exterior walls bokeh Building & Construction 3 05-06-2011 02:12 PM
I want to make interior walls look like stucco marylee Drywall & Plaster 3 03-27-2010 08:25 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 04:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
