Stucco - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-30-2013, 08:45 AM   #1
Rewards Points: 154
stucco
anyone have any pointers on how to stucco? what tools are needed?
i have a little patch job to be done at home
thanks
awdblazer is offline   Reply With Quote
Old 08-02-2013, 06:32 AM   #2
Rewards Points: 154
21 views and not one post!
bump!
Old 08-02-2013, 04:28 PM   #3
Rewards Points: 1,232
Too broad a question, kind of like, "How much does a car cost".
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 08-02-2013, 04:47 PM   #4
Rewards Points: 4,732
or tiecost ? by the time you get the tools, coloring agent, genuine/synthetic materials, you're probably better off hiring it done - craig's list
bump back !
stadry is online now   Reply With Quote
Old 08-02-2013, 04:52 PM   #5
HOWEVER, if you're still of a mind to do it, you'll need couple of trowels ( i like pool trowels ), a scarifier, mason's brush, fiberglass sheeting, 4" grinder & diamond blade, 1/2" mixing drill ( a TRUE 1/2" [550rpm] ) + material & pigment if you mix your own color,,, w/any luck, you'll match the existing color on the house,,, IF you do happen to match it ( even closely ), consider it a miracle delivered by the stucco gawds
why they will have chosen to smile upon you, only they know
Old 08-05-2013, 09:16 PM   #6
Rewards Points: 154
its white stucco and its maybe two inches on each side of a door plus about a foot above the door
and isn't this diychatroom? not a call a pro?
Old 08-06-2013, 05:38 AM   #7
sure is,,, or at least the url sez it is,,, ok, just mix up some plaster, fine aggregate ( white sand ), & white cement,,, add some water til the consistency's just right & apply
Old 08-06-2013, 06:30 AM   #8
Rewards Points: 154
I have type s mortar I believe for the undercoat plus I have stucco mix
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 06:23 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
