Stone Veneer Over Pressure Treated Posts - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-04-2012, 05:55 AM   #1
stone veneer over pressure treated posts
Hi. This is my first time using this tool to find answers to issues I am encountering with a new house build.
I have a covered verandah of poured concrete 8x10. To support the cover, my contractor used 6x6 pressure treated posts. I wanted these finished as they were quite unattractive as is so I had a stone mason cover them with stone veneer. The posts at 6 inches square were not substantial enough, asthetically speaking, so I nailed 2 x8's to them to build them out. Next I covered them with tyvek house wrap and then nailed metal lath over the tyvek. This was the substrate the masons mortared the 0ne inch thickness stone veneer to. It lasted one winter and now each post has a crack down the west (outward facing side) almost the entire length of the post.Tell me what went wrong.As much as I can live with the crack, I can picture it getting bigger with each passing freeze and thaw cycle through the cold season (mid western Ontario). Any ideas, suggestions, comments will be most appreciated. Thanks.
buddyvermontari is offline   Reply With Quote
Old 05-04-2012, 11:40 AM   #2
Concrete & Masonry
Rewards Points: 530
This is fairly common, especially on posts with 4 corners close together. The problem most likely is that the Tyvek isn't keeping water away from the wood. Cultured stone is absorbant, like a sponge, and takes in and can store more than enough water to saturate the wood material behind it. Tyvek works well under some cladding, not so well though directly under thin adhered masonry. Odd's are the wood is swelling under the Tyvek, and considering the stone veneer has little flexibility, it's telegraghing through to the surface.
For more info, google "solar driven moisture - masonry"..........
jomama45 is offline   Reply With Quote
Old 05-04-2012, 12:07 PM   #3
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
My preferred method of achieving a column like this is a little different, but then again I live in Florida.
From a pressure treated 2 by structure I use 5/8" exterior plywood covered in your preferred moisture barrier and sealed. Cover all surfaces with expanded metal sheathing, overlapping at any joints and also around corners, nail every 6"or so with galvanized round headed nails
I use Thin-set as a bonding agent and working from the bottom apply your exterior stone veneer to all four surfaces as you move up the column. Force the Thin-set into the expanded metal sheathing thick enough to cover all area at the back of stone veneer. Next fill all joints with manufactures recommendation of mortar or grout
This has always worked well for me in Florida.
Woody4249
woody4249 is offline   Reply With Quote
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 05:57 PM
Pressure treated posts set in concrete? zubin6220 Building & Construction 19 08-13-2013 06:39 AM
How to install veneer stone over gas fireplace lvanloon Concrete, Stone & Masonry 2 03-05-2012 10:54 AM
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 04:04 PM
Stone veneer over painted block Daystepper Building & Construction 0 09-16-2010 05:03 PM
