Stone Veneer Fence Colums - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-03-2013, 12:57 AM   #1
Stone veneer fence colums
Hello-
I'm making a decorative fence to go around a graveyard for Halloween. Since it's purely for decoration and will only be outside for a few weeks in October, weight and a realistic look is my primary concern. However, living in Colorado, it also needs to be fairly weather resistant as well.
The fencing sections are complete (wood and pvc) and now I'm making some columns to put between the sections. I plan on using 2x2 framing and 7/16 osb sheathing. I'm making my own stones and using perlite or crushed lava rock or styrofoam as aggregate for weight saving with the stones.
What's the best way to attach the stones for this application? For normal construction I'd use mortar and wire lathe and heavier/stronger stones. However I'm thinking a simple mastic would work for my purposes. I plan on using a mortar grout in between the stones and having a concrete (same concrete recipe) cap on the columns so the only water issues I should face are snow or rain coming in from the sides or from the interior wood sitting on the ground.
Any issues using mastic or grout for between the stones directly on osb? Any other issues I should be looking for? Also, any ideas for weight saving are welcome.
Thanks for your time
sy44 is offline   Reply With Quote
Old 09-03-2013, 10:13 PM   #2
Rewards Points: 142
i wouldn't use mastic. i would use outdoor caulking. and perhaps a grey colored caulk for grout.
Fix'n it is offline   Reply With Quote
Old 09-04-2013, 12:34 AM   #3
Hadn't even considered a gray colored caulk for grout. Thanks! Great suggestion!
Old 09-04-2013, 08:10 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
You might want to look at FauxPanels. Polyurethane means weatherproof, light weight and easy installation. Should be available locally but could be special order.
http://www.fauxpanels.com
12penny is offline   Reply With Quote
Old 09-05-2013, 08:25 PM   #5
Love fauxpanels. Realistic look and lightweight... just don't love the price.
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 07:39 PM
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 05:57 PM
Installing natual stone veneer on concret basement walls js1979 Concrete, Stone & Masonry 6 06-04-2013 10:53 AM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
