Stone/Masonry Fire Pit Project - Need Advice - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-03-2012, 01:30 PM   #1
Smile
Stone/Masonry fire pit project - Need Advice
I am looking to build a fire pit. I am wondering what type of construction material is best suited for this. What I have been looking at are concrete bricks, building bricks (made from dirt, sand, water) and stone bricks.
I know the cheapest is concrete bricks however my son has seen concrete ones (blocks) explode when they got hot from being near a fire. I do not know if this is unusual or if they are just not made for this type of heat.
The next step up is building bricks (the typical RED ones), but they are small and it would require a lot to build up the pit.
The third choice is the stone bricks. These are great looking and have a lot of choices, however they are the most expensive.
The stones that I have seen are granite, flagstone, limestone.
I am looking for something that is durable and not cost too much money.
Any suggestions?
lolafox12 is offline   Reply With Quote
Old 08-03-2012, 02:06 PM   #2
DIY-er
Stone is the best option, it doesn't heat up. Many firepits have a metal drum buried into the ground with bricks on the outside of it.
KevinPh is offline   Reply With Quote
Old 08-03-2012, 04:29 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
spalling of concrete is possible when trapped moisture is heated and converted to steam .... I do not know how common it would be for concrete pavers/bricks to explode, but there is the potential for them to crack and come apart, how violently is anyone's guess
http://www.diynetwork.com/outdoors/8...es/page-8.html could always purchase a metal fire pit
here are some samples of DIY fire pits, and yes I agree with Kevin, stone would be the best choice even if it is the more expensive way of doing it ...... notice the saying on my signature
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-03-2012, 06:25 PM   #4
Smile
fire pit
ty for the reply!
The pictures give me some good ideas to work with.
I already have a metal fire pit. It is quite small.
I am looking for something @2x that size.
Old 08-03-2012, 08:32 PM   #5
Too Short? Cut it Again!
Make sure you check code to see what you are allowed in terms of BTUs and at what proximity to your home. Some communities are enforcing more and more strict regs on woodburning too so you might want to run a line for gas adaptation for future use when building this.
Old 10-01-2012, 10:41 PM   #6
Some Ideas about Fire Pits
Thought I need to share my recent blog site and perhaps it might help.
Enjoy
Last edited by Gary in WA; 10-01-2012 at 11:04 PM. Reason: Web link belongs under your signature line.
reachout is offline   Reply With Quote
Old 10-01-2012, 11:15 PM   #7
bml.4517's Avatar
I have built one three years ago up on top of a mountain on my property. It was made simply from river rock...its free and its from nature.
It is still standing and in use so...its a thought
bml.4517 is offline   Reply With Quote
Old 10-01-2012, 11:20 PM   #8
amazing - just real nature it is
plywood on fire rated wall acerunner Building & Construction 9 11-18-2016 07:15 PM
Electrical Fire seansy59 Electrical 1 10-24-2011 06:57 PM
I need advice on a home project it involves PVC and copper tubing please help Mufasa02 Off Topic 8 08-16-2011 07:08 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Do they make internet enabled fire detectors? Red Squirrel Safety 3 08-30-2010 04:39 PM
