Stone Lifting Tongs - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-25-2013, 04:21 PM   #1
Stone lifting tongs
I am rebuilding a stone chimney in my log cabin. Some of the stones are 50-200 pounds. I would like to set up a homemade crane using pipes, block and tackle and something to grab the rocks.
I see lots of two prong tongs online but no 3 or 4 prong ones.
I don't see how a two pronged device will safely hold an odd shaped rock.
The rock lifting tongs I do see online are huge, for ton sized rocks for use with a backhoe.
Any ideas?
jfabris is offline   Reply With Quote
Old 03-26-2013, 01:26 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
I've never had to do this, but I would think a bag system made from a heavy duty tarp (not wal-mart $15 plastic) would work. place stone on tarp and attaches eyelets/grommets to hoist.
once one using tarp to life stones could always find a use around the cabin.
just a thought ..... Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-26-2013, 01:34 PM   #3
Well, the problem with that is I need to be able to place the stone right into position, so the grabbing device needs to lift from the sides/top.
Old 03-26-2013, 05:26 PM   #4
Rewards Points: 4,534
pin & feather or lewis pins will take too long to cut into the stone so try ' lifting dogs ' - granite city tool ( barre, vt ) or miles supply ( elberton, ga ) [ no financial interest ]
or, if you're a cheap h/o - diy'er like the rest of us, make your own after looking at them online
The Following User Says Thank You to stadry For This Useful Post:
GBrackins (03-26-2013)
Old 03-18-2014, 04:43 PM   #5
Tongs for Rocks
If you can weld you can make
these tongs for rocks, I use an engine hoist to pick them up and move them. Works like an old ice block lifter.
pedromtt is offline   Reply With Quote
Old 03-18-2014, 09:34 PM   #6
Rewards Points: 3,416
All depends on what kind of stone your talking about, something round like field stone or flat like limestone.
Canarywood1 is offline   Reply With Quote
Old 03-18-2014, 10:22 PM   #7
Msradell's Avatar
Rewards Points: 126
Hopefully the OP has solved this problem considering this thread is one year old!
Msradell is offline   Reply With Quote
Old 03-19-2014, 10:39 AM   #8
Update
Msradell, good point about old threads, perhaps members can also post the solutions, along with pictures that they used. It would be nice that way we will have best practices/solutions.
Old 03-23-2014, 01:06 PM   #9
Rewards Points: 152
The best way to move stone is simple. Check out "coral castle" on youtube. You will find all your answers there. GL
TRUEPRO is offline   Reply With Quote
Old 03-24-2014, 02:37 PM   #10
Corral Rock Castle
Truepro, thank you for directing me to Corral Castle, it has been in the back of my mind, I saw the episode that Leonard Nimoy did back in the 70's, when into yutube to see the latest as you suggested. I will tell you this, the hoist and tackle is good but Edward Leedskalnin used it as a divertion. As for his treasure he left behind it is not in $$, but in knowledge. I plan to some day visit the original site where he started and then move to.
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate? Minich Remodeling 8 02-01-2012 09:27 AM
Changing the color of stone misayo Interior Decorating 3 01-16-2012 03:59 PM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 04:41 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
