Stone Foundation With Large Gaps And Cracks - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-30-2009, 07:15 PM   #16
Knucklez's Avatar
Rewards Points: 932
ya.. this old house has me full time job fix'n stuff
hey, it held up great. no micro cracks or anything. and my kitchen was MUCH warmer this past winter, and the mice were .. dunno .. outside i guess. i did not parge it yet as i wanted to see if the mortar held up on its own before i cover it.
when i excavate my basement i'll take a more serious look at it.. well, a structural engineer will - not me.
i did not research any interior solutions as in my case there was just a crawl space on the other side (i.e. "the cat hole") that nobody wants to go into .. believe me.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 07-23-2012, 06:02 PM   #17
There is a company in Ohio, called Airplaco that makes a "Handy Grout" manual mortar/ grout pump that fits into a bucket and pumps material by a hand pump , like an old well pump handle, It has a 6ft hose and @ 200 psi. Problem is cost, @ $1,000. I looked to rent one in central Indiana, no one has it. I may have to go to Indianapolis to find. I too have a stone foundation and due to a recent infestation of rats/mice, several "holes" and "cracks" need to be filled. Good Luck, Ray
Rayburn is offline   Reply With Quote
Old 04-07-2016, 05:32 AM   #18
Rewards Points: 2
Re: Stone Foundation with large gaps and cracks
Have aTyndal stone foundation. Inside has gap about 4 inches X 8 inches X 14 inches near window frame. From what I read: 1) clean out well 2) spritz with water 3)coat with bonding agent 4) insert small stones and premixed mortar mix from hardware store with some bonding agent added 5) apply parge top coat after dry and seems OK
Do I have it right? Most pros don't want to be bothered with such a small job.
rmarion is offline   Reply With Quote
Old 04-07-2016, 11:34 AM   #19
Rewards Points: 3,520
The easy way is polyurethane injection if it's not a structural problem, epoxy if it is, this may help.
http://www.emecole.com/pages/product...tml#foundation
Canarywood1 is offline   Reply With Quote
Wedge cracks STG Building & Construction 4 07-01-2008 10:41 AM
