Stone Fireplace - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-20-2014, 01:29 PM   #1
Rewards Points: 12
stone fireplace
Not sure if this the appropriate place for this...
Anyways I have this tall stone fireplace from the 70s. I will attach a pic. I took the old wood burning insert out and will be installing another this summer.
I need some ideas on how to prepare this for a refacing. At first I was thinking of ripping this all down... But as it being 16' tall and its all concrete and large stones, not sure how to do this safely. I just need to somehow get a flat surface... The bottom half of the stone wall stick out a good bit more than the top half so not sure if mudding it would help much. Thanks for any suggestions.
tool man Taylor is offline   Reply With Quote
Old 03-20-2014, 01:31 PM   #2
Rewards Points: 12
Old 03-20-2014, 09:37 PM   #3
Msradell's Avatar
Rewards Points: 172
A lot will depend on what you are planning on putting over the existing stone. Personally, I think the stone looks very nice and fits the style of the home but that's my opinion and you want to do something different. Tell us a little more about what you are planning on doing and we may be able to help you some more.
Msradell is offline   Reply With Quote
Old 03-20-2014, 10:11 PM   #4
Rewards Points: 12
Yea I agree. It does fit the house... The exterior of the house has this same rock. The rock on the exterior however looks much better and we like it. On the fireplace it doesn't look as good... The joints are much bigger and that spot right above the opening and right below the mantel is just flat concrete and looks strange.
As far as what we planned to do is up in the air ... Originally was planning a stack stone look but no decision has been made... I have seen some bare concrete facing on fireplaces that I like also. I'm kinda concerned that a stack stone would look out of place since the exterior has this type of stone work.
Old 03-21-2014, 09:30 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Most of the manufacturers of the stacked stone facings have recommendations and requirements for attachment and bonding. Best to stay within their guidelines.
Old 03-21-2014, 02:21 PM   #6
Rewards Points: 12
Thanks. Yea Im with u on that 100%.
Guess my question is what would someone with experience do to this fireplace as far as preparing it to be refaced...
Because no matter what its going to be refaced with it needs to be square and flat.
Tearing this out and framing a flat surface would obviously work... If this is recommended how would you tear this out safely?
Old 03-21-2014, 06:47 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,.... Ya kinda gotta know exactly What ya wanta see there, before you can come up with a plan to get there,....
Stucco it,..??....
Bondo is online now   Reply With Quote
Old 03-21-2014, 07:16 PM   #8
Rewards Points: 12
Youre right about that.
I guess in my mind its either going to be tile or stacked stone. Which is why I suspect they both need a flat surface ( I know tile does anyways). I never thought about stucco.
Let's say we are prepping for a stacked stone since that's what we originally planned.
Old 03-21-2014, 09:10 PM   #9
Msradell's Avatar
Rewards Points: 172
Obviously tile will require a perfectly flat subsurface, stacked stone will not require the service to be completely flat because the stones themselves are slightly irregular. If you decide to go with stucco how flat it needs to be would be dependent on the type of stucco look you want.
In order of difficulty, a rustic stucco look would be the easiest, stacked stone next anti-would certainly be the hardest for many reasons.
Old 03-23-2014, 01:44 PM   #10
Rewards Points: 1,232
Adhered veneer (either tile or faux stone) can be considered to be the finish coat of a stucco system. As such, the brown coat (or surface that is equivalent, like your fireplace) only needs to be smooth enough to allow you to adhere the finish to the degree of flatness you want. For a faux stack stone, you can probably adhere it directly to the existing surface, for tile you would want to float it out level +/- 1/4"
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 03-24-2014, 05:47 AM   #11
Rewards Points: 4,578
might try elitecrete.com, concretelocator.com, or concretenetwork.com for ideas/technique/finished look. you can apply concrete overlay then finish as you wish,,, or not,,, we usually use mechanically attached expanded wire mesh sheets 1st.
no $ int - irc
Stacked Stone Fireplace Makeover Help SMRcalidiv Concrete, Stone & Masonry 9 01-13-2014 10:48 PM
Making a Mantle for a Stone Fireplace. Two Knots Building & Construction 10 10-24-2013 05:53 PM
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 04:57 PM
Fireplace w/ TV focus point. Stone to ceiling or not? POLL 6fthook Interior Decorating 2 05-25-2011 09:02 PM
