Step Cracks - Exterior Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-10-2014, 12:00 PM   #1
GBunny
Rewards Points: 71
I have step cracks in the mortar leading from a basement window to a ground floor window. I assume the wall has shifted slightly maybe because there is no lintel. The ground floor window does not slide as easily as before.
How do I find out what caused the damage? Could it be from the weight of the snow on the roof last winter?
If I have a lintel installed, are there any precautions they need to take before removing the window? Will this ward off future problems or is there something else we should be looking for?
Here are some photos.
https://www.dropbox.com/sh/ys7behjob...%20CRACKS?dl=0
GBunny is offline   Reply With Quote
Old 12-10-2014, 12:11 PM   #2
Rewards Points: 1,232
Normally, step cracks are shrinkage cracks. If the cracking extends through the units, then it is probably a foundation issue. Concrete block or concrete brick are as big as they are ever going to be when put in the wall (they shrink, as does the mortar with time), clay brick are as small as they will ever be when put in the wall (they expand with time).
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 12-10-2014, 12:59 PM   #3
GBunny
Rewards Points: 71
The house was built in 1974. The cracks formed in the last year. I would notice that in the winter, some doors if left slightly ajar would open by themselves but in the spring the process would correct itself. This past spring, it did not correct itself.
Old 12-10-2014, 04:03 PM   #4
It sounds like some settling issues then.
The Following User Says Thank You to Tscarborough For This Useful Post:
stadry (12-10-2014)
screed the top of a concrete step etaf Concrete, Stone & Masonry 12 11-01-2014 10:26 PM
Preparing 1st step for over-the-post starting newel hkeiner Carpentry 9 03-18-2013 12:02 PM
Can starting step tread be 3/4" deeper than other treads? hkeiner Carpentry 8 02-18-2013 10:24 PM
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 04:23 AM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
