Steel Support Beams On Basement Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-30-2012, 08:06 PM   #1
Rewards Points: 105
Steel support beams on basement wall
Just wanted to get some opinions on a possible home purchase. This 1500 sq ft ranch home built in 76' i'm looking at has the steel support beams, up to the floor joist, on the entire north basement wall. For the most part, the wall looks ok. There are some small cracks both vertical and horizontal. Is this something that can be contained over the coming years or could there be additional problems down the road. The south side of the basement wall has been painted recently too it looks like. Any advice on this is appreciated, thanks.
gmbwrenchn is offline   Reply With Quote
Old 04-30-2012, 08:49 PM   #2
Rewards Points: 13,732
And the pictures are where? Sure would help if we could see what your seeing.
So far does not sound good.
A beam in the center of the house is one thing, on an out side wall can be very bad, may be the foundation was starting to bow in.
Old 04-30-2012, 08:56 PM   #3
Rewards Points: 105
Yea.......sorry no pic's. Went to an open house. Maybe next time i'll bring a camera. There along the entire north wall. Would you consider buying a home like this? Thanks.
Old 04-30-2012, 09:00 PM   #4
No idea until I see it.
Not sure what your looking at, then hire your own home inspector or an engineer before buying. Never ever use one a realitor suggest.
Old 04-30-2012, 09:13 PM   #5
Rewards Points: 105
Thanks for the advice.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
