Stamped Concrete Patio Sealer - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-16-2012, 07:32 AM   #1
stamped concrete patio sealer
just had a stamped patio put in project took some time due to some extended work, but all is done and looks great. the contractor put on the first clear sealant and will put on the final. so if i where to buy a clear sealant and there might be many , what would i be looking for ?
tav1 is offline   Reply With Quote
Old 07-16-2012, 08:13 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
Depends on what the contractor uses. Most will use a clear solvent stain (xylene base) and some will use water based acrylics. If solvent stain is used then you should recoat with this in the future to avoid adhesion issues. Other sealers are used but these are the most common. Talk to your contractor and get the info from him to avoid future problems.
mustangmike3789 is offline   Reply With Quote
Old 07-20-2012, 08:31 PM   #3
Rewards Points: 3,622
In other words if you use xylene you will never be able to use anything else,so choose wisely the first time.
Canarywood1 is offline   Reply With Quote
Old 07-20-2012, 11:22 PM   #4
I would go with conspec j23 or spec Chem deco shine plus.
Sent from my iPod touch using DIY Forum
slimcutta is offline   Reply With Quote
How to replace concrete patio that extends under a brick wall? brad77 Building & Construction 5 12-26-2011 10:49 PM
Stamped concrete kathy103 Landscaping & Lawn Care 10 10-27-2011 06:51 PM
Concrete Patio TCS-Austin Building & Construction 0 04-21-2011 02:25 PM
Concrete Patio drainage issues kozmo99 Building & Construction 3 06-20-2010 09:49 AM
Stamped Concrete Sealer cgoll Building & Construction 1 06-24-2008 06:15 PM
