Stamped Concrete Patio - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-11-2012, 01:05 AM   #1
Rewards Points: 27
I’m having a stamped concrete patio put and in the contract it says 4” thick.
I was looking at the forms and noticed that they were 2x4’s and realized, “Hey, those are only 3.5 inches thick”. I got a string and measured the center and other areas thinking that maybe it was just edges were 3.5 inches. From what I can tell, in almost every place it’s almost perfect at 3.5 inches.
So is concrete thickness like lumber thickness with a nominal and actual? Should I say anything? The concrete hasn’t been poured yet, so I imagine it's a lot easier to fix it now than later.
marly is offline   Reply With Quote
Old 08-11-2012, 10:57 AM   #2
Rewards Points: 3,426
No concrete is not nominal,get a better measurement by laying a 2x4 across the forms and measure down from there.
Canarywood1 is offline   Reply With Quote
Old 08-11-2012, 02:35 PM   #3
Too Short? Cut it Again!
Sounds like somebody measured wrong and set the forms 1/2" off. He/she will not be a happy camper but not your problem. Good you caught it.
Old 08-11-2012, 04:49 PM   #4
Rewards Points: 27
I tried using the 2x4 across the forms and I did get a different measurement. I was getting about 4.25 to 4.50 in some areas. I was only able to test in five different spots, but that seems good enough. I tired making the string as tight as I could and I got 3.75, so it must just be the string.
Old 08-11-2012, 06:32 PM   #5
Glad to hear it turned out alright,enjoy your new patio.
Old 08-12-2012, 12:01 PM   #6
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Remember, 4" is ideal, but rarely will your whole slab be that thick. The contractor will do as much as he can to get the subgrade completely level and perfect, but in reality, some of the slab will be 5" thick, others will be 3 1/2. The top 1 millimeter is all you see, so if it doesn't crack, and you're not parking a 747 on it, if its a little thin in some places, its alright.
Mort is online now   Reply With Quote
Old 08-12-2012, 08:12 PM   #7
Rewards Points: 152
The 1/2" in question here can easily be made up with a rake and plate compactor or tamp. No need to worry about it cracking thats a guarantee just be sure they cut control joints. GL
TRUEPRO is offline   Reply With Quote
Deck over concrete patio PAmbrose Building & Construction 16 08-21-2012 11:23 PM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 08:41 PM
Concrete Patio Enclose with Pressure Treated Wood ryanb4614 Concrete, Stone & Masonry 8 04-23-2012 07:22 AM
Ideas for deck over concrete patio and beyond-pics- bdobs Building & Construction 6 05-10-2009 09:58 PM
Concrete Patio sah Landscaping & Lawn Care 1 07-13-2008 08:27 PM
